MSD Tach adaptor needed?
I am using 2 X MSD units and 2 X Blaster coils for my twin plug ignition, will the tach read correctly or do i need an adaptor?
72 Targa Wade
-Wade 1972 Targa, nothing matching. Looking for motor 6124265 and transmission 7720299 |
If you need i have one in almost new condition
1966 912 with 2.2 911 motor 1986 wide body 911 1995 993 Polar Silver |
also have msd 6 btm with tach adapter and blaster coil
Short Answer- Using a OEM tach- Yes.
I sent my speedo to a shop where they made the change internally to work with a MSD box.
Chad Plavan 911ST Race Car/2.5L SS Race Motor #02 1972 911T- Numbers matching- Restoring to stock 2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold) 2016 Elan NP01 Prototype racecar- Chassis #20, #02 |
Banned
I have an OEM Tach and don't need an adaptor. Re read your MSD manual, there is a spade connector on the end of the MSD unit. The tach wire plugs directly into that and reads RPMs from the MSD unit.
It's worth a try, it worked on mine. |
Wer bremst verliert
I've had early tachs work and not work, late tachs work and not work. My experience is hit-and miss so you might try it first before ordering an adapter.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Thanks for the replies, I'll see if it works
W
Thread Tools | |
Rate This Thread | |
