Always looking for speed
Testing spark plug wires with a multimeter (ohms)
Ok I've searched around the forums and on the web and I'm getting conflicting info on how to test the spark plug wires. I know there are other more definitive ways to test the wires but I wanted to just do a quick ohm test.
This is what I did but please educate me:
Set mutimeter to ohm or Ω setting at 20K
Connect the red meter cord to one end of the wire and the black meter cord on the other end
Reading is 1.56 (wire is about 1.5ft)
So I'm assuming this is good since it has low resistance but I'm seeing conflicting articles on the web that say it should be reading between 6-8.
So whats right? or is my wire ok base on this quick check?
Thanks!
Old 02-07-2013, 10:55 AM
ROW '78 911 Targa
timmy2's Avatar
My memory tells me they should all read 4k ohms with boot attached for factory Beru wires. 3k on wire 1k for boot.
My memory is failing, reverse theose numbers...
Old 02-07-2013, 11:24 AM
Capitalist and Patriot
911Freak's Avatar
Sub'd I'd like to know definitively as well. There has to be a variance between plug wire lengths and the acceptable ohm range, no?
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 02-07-2013, 11:59 AM
Functionista
manbridge 74's Avatar
The standard has generally been 1000 ohms per foot for non resistor wires. Not sure on Beru as I've never checked.
Old 02-07-2013, 12:04 PM
I have the Beru wires and I'm pretty sure they've been changed out since new. Can't imagine the wires lasting that long.
Ok rookie question: is the beru a non resistor wire?
Thanks!
Old 02-07-2013, 01:08 PM
the steel core wire won't give much resistance. you need to take the ends off and measure them separately. 3K is normal for the plug ends and depending on which distributor end you have, it's generally no resistance or 1K. later wires have a crimp on end that threads into the connector and it can get stuck and lead to wire damage if you're not careful getting it loose.
206 637 4071
Old 02-07-2013, 01:31 PM
Thanks - I have a 1969 911T and I switched out the distributor for a bosch.
I'm trying to understand what you mean by 3K for plug ends - the way I'm measuring is removing #1 wire and testing the continuity. and its coming out to 1.56 with the multimeter set at 20K.
Old 02-07-2013, 01:46 PM
3000 ohms resistance. (3K). some of the early cars had black connectors that measured 1K. the brown ones are 3k.
206 637 4071
Old 02-07-2013, 03:11 PM
ok - the connectors I have are gold in color so they should be at 3K.
Old 02-07-2013, 04:31 PM
Detached Member
Hugh R's Avatar
Why so much resistance? To raise the voltage? IIRC, on Lucas copper plug wires, I'd get like one ohm or something.
Hugh
Old 02-07-2013, 04:42 PM
wwest's Avatar
Thanks!
The difference is the result of availability of nichrome wire resistance vs carbon cranules.
Old 02-07-2013, 04:50 PM
Are the Beru wires nichrome or carbon cranules?
So far I know they are standard non braided steel wires so they are nichrome? which means 1.56ohms is good?
Cheers!
Old 02-07-2013, 05:11 PM
Cheers!
Or just steel, plated steel or stainless steel plug wire conductors. Early 911s don't have electronics (other than a radio) that may be compromised by RFI caused by these wire conductors.
You may also want to check the resistance from each spark plug connector to the appropriate copper terminal under the distributor cap. Corrosion and/or a loose connection can increase the resistance to a threshold that creates borderline misfires.
Sherwood
Old 02-07-2013, 10:52 PM
So here is the latest. I tested all spark plug wires with the following results:
#1: 1.52
#2: 1.40
#3: 1.58
#4: 1.50
#5: Nothing - did not register
#6: Nothing - did not register
Looks like #5 and #6 are dead as the meter did not register anything. Basically no continuity.
Old 02-09-2013, 06:07 PM
Oh Haha's Avatar
Ok, please help me understand. The SC is running like crap.
I am down to checking the plug wires.
Meter set to 20k on the ohm setting.
I tested the wires w both connector ends attached and come up with readings of 4.15 for cyl 2 which is about 1.5 ft long.
Is this good or bad?
Wires are Beru shielded.
Pacific Blue
Wayne
Old 04-03-2015, 10:10 AM
Depends on the knob setting on your meter.
Analog or digital?
I assume different resistance range settings
If "20K" is the measurement range, 4.15 could be 4000 ohms. Plug wire is fine.
If "20K" is a multiplier, 4.15 could be 80K ohms. Plug wire is NG
How about the other plug wires? That would give you some reference point. If the readings are more or less consistent on all, either all are OK or all decided to die in unison (not likely unless subject to a common fire/barbecue).
What is your definition of "running like crap"? While emotionally understandable, it's not too descriptive for potential hints other than "replace everything". Describing symptoms would be easier to diagnose (E.g. at idle, under load, cold vs hot, backfires, misfires, no power at high rpm, etc.).
Sherwood
(not that I could assist even with all that info)
Old 04-03-2015, 11:14 AM
Oh Haha's Avatar
Analog or digital?
Sherwood
Thanks Sherwood. I've asked the same of posters(running like crap comment) so I should know better.
I was trying to diagnose my SC which was down on power and rough running, like not banging on all cylinders. I was to the point of checking the ignition system and I had never checked my wires in the years I owned the car. It turns out the issue was a clogged fuel injector and old fuel. She's running great again.
Pacific Blue
Wayne
Old 04-03-2015, 12:13 PM
Wayne,
Glad I could help.
Just don't call me Shirley (Airplane, 1980).
Old 04-03-2015, 01:40 PM
Oh Haha's Avatar
Fixed it. Sorry bout that.
Pacific Blue
Wayne
Old 04-03-2015, 01:45 PM
DanielDudley's Avatar
Testing spark plug wires can tell you if they are bad, but it won't absolutely prove that they are good, as the insulation can break down, and arcing can occur on an otherwise ''good'' wire.
If your wires look old, an you have never replaced them, do so. Likewise with the cap and rotor.
Old 04-03-2015, 01:54 PM
