Did you get the memo?
onewhippedpuppy's Avatar
Footwell Blower Troubleshooting Help Needed
I just completed a heater backdate on my '88 Carrera, and am having issues with getting the footwell blowers to work. This car does not have the automatic heat, it has the heater levers and 3-position switch to control the blowers. Here's what I've done so far:
Heater blower relay reed switch bypass
Checked all front fuses and connections
Checked all rear fuses and connections
No voltage at footwell blowers
Front relay clicks when pulling up on the left and right heater levers
No voltage at 3-position switch that controls footwell blowers
My FSM wiring diagrams only cover models with automatic heat, so I'm left guessing as to the power distribution with the simpler heating system. If anyone has the correct diagram that would be a big help. Any suggestions welcome.
‘07 Mazda RX8-8
Old 02-10-2013, 12:40 PM
gjs
glennspiegler's Avatar
In my 88 carerra when the rear engine hot air motor blew, the power to the footwell blowers went out. Meant to be this way. Good luck. Glenn
88 911 Carrera Cab, SW chip, B&B headers, custom sport muff
2015 Cayman S
1948 Willy's Overland Jeepster
2013 Chev Sub
2004 Nisson Xterra
Old 02-10-2013, 12:55 PM
Bump, any suggestions?
‘07 Mazda RX8-8
Old 02-10-2013, 07:42 PM
pete3799's Avatar
This any help or have you read it already.
Help! Does anyone understand the footwell blower circuit?
Pete
79 911SC RoW
Old 02-10-2013, 08:01 PM
Pete, I somehow missed that in my searching. Excellent thread that should be very useful, thanks!
‘07 Mazda RX8-8
Old 02-11-2013, 07:13 AM
