setting clutch help....PLEASE!!!!
...pretty certain i got the engine and tranny mated well, and i am just about done with complete re-install of motor of 1986 930, when i realize the one picture i didnt get was of the clutch down below before i release the tension...also, my clutch pedal is on the floorboard, springing back down when i pull it up...have done everything according to waynes books, tech forums, etc, and would really appreciate help...thanks...
Old 02-10-2013, 12:53 PM
Senior Advisor
James Brown's Avatar
no problem, just follow the instructions on clutch cable replacement in the tech articles or your repair manual.
08 Cayenne Turbo
Old 02-10-2013, 01:00 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Remember it is two stage process:
1. gap at the clutch arm with out cable is 1.20MM, with cable and tensioned it needs to be reduced to 1.00MM, have a helper keep the pedal up after you install the cable to the clutch helper arm.
2. the difference between pressed and unpressed clutch pedal must be 25.0MM +/- 0.5MM, this is adjusted at the floor board stop ( that metal plates with two allen bolts and a rubber cushion. You defnitely need a helper here as you sound off the readings below.
That is it, clutch should release and engage half way on the pedal throw.
Jim
'85 Carrera Targa
PCA/POC
Old 02-10-2013, 03:31 PM
thanks guys, just had a helluva time prying the omega spring into place...now waiting on a helper for the adjustment...cheers!!!
Old 02-10-2013, 06:40 PM
DRACO A5OG's Avatar
Just use a BFS and pop it over.
When you remove and install the cable you will push it over to make it easier, a hint
'85 Carrera Targa
PCA/POC
Old 02-10-2013, 09:21 PM
