Un Canadien Errant
aldente295's Avatar
remote trunk release
Has anyone successfully installed a remote front trunk release? I have a button on my remote lock/alarm and have often thought it would be convenient to have this added functionality. The solenoid/relay kit is cheap, but apparently installation is 'tricky'.
Alan
1980 911SC - 'Brian'
Old 02-10-2013, 05:19 PM
80-911SC's Avatar
shouldn't be "tricky" .. 30/45 lb pull solenoid is all you need .. then either wire trigger to a switch or a remote ... I would leave the stock set up in place and hook off the end of the arm rather than replace ... use the stock one as an emergency pull ...
Old 02-10-2013, 08:03 PM
Un Canadien Errant
aldente295's Avatar
I suspect the tricky bit may be figuring out exactly where/how to mount the solenoid. Hoping for some pix from folks who have done it before.
Alan
Old 02-10-2013, 09:09 PM
