Did you get the memo?
Footwell Blower Troubleshooting Help Needed
I just completed a heater backdate on my '88 Carrera, and am having issues with getting the footwell blowers to work. This car does not have the automatic heat, it has the heater levers and 3-position switch to control the blowers. Here's what I've done so far:
Heater blower relay reed switch bypass Checked all front fuses and connections Checked all rear fuses and connections No voltage at footwell blowers Front relay clicks when pulling up on the left and right heater levers No voltage at 3-position switch that controls footwell blowers My FSM wiring diagrams only cover models with automatic heat, so I'm left guessing as to the power distribution with the simpler heating system. If anyone has the correct diagram that would be a big help. Any suggestions welcome.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
gjs
In my 88 carerra when the rear engine hot air motor blew, the power to the footwell blowers went out. Meant to be this way. Good luck. Glenn
88 911 Carrera Cab, SW chip, B&B headers, custom sport muff 2015 Cayman S 1948 Willy's Overland Jeepster 2013 Chev Sub 2004 Nisson Xterra |
Bump, any suggestions?
This any help or have you read it already.
Help! Does anyone understand the footwell blower circuit?
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
