Follow me
seymore's Avatar
Reuse oil filter.
Hey guys
This will be a first for me. I always change my filter when I change the oil. But hear me out.
I read somewhere that even if you don't drive you car that often, lets say 500 to 1000 miles a year you should change the oil every year.
I am wondering if I need to change the filter just because I change the oil?
Can I just take it off and dump out the old oil and reinstall it? Its almost brand new.
Thanks guys
1982 911SC
Old 02-15-2013, 03:59 PM
Oh Haha's Avatar
Change it. Consider it cheap insurance.
Oh yeah-drive your car more!!
Pacific Blue
Wayne
Old 02-15-2013, 04:03 PM
Banned
13 bucks .... change them
Pelican Parts - Product Information: 930-107-764-01-M1100
Old 02-15-2013, 04:15 PM
change it every time. I consider the Porsche filter to be on par with a Fram. Use Mahle each time.
Old 02-15-2013, 05:05 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
EEEEwwww....that's like putting on dirty underwear after taking a shower.
Bob
Bob Hutson
Old 02-15-2013, 05:21 PM
Undocumented User
McLaren-TAG's Avatar
Bob
Go commando!
Old 02-15-2013, 05:34 PM
Follow me
seymore's Avatar
I ordered one!
I just already have the oil and wanted to change it first thing in the morning and take it on a trip this weekend.
I didnt want to wait until next friday to get the filter.
The filter that's in it only has maybe 500 miles on it. its been worked on a lot the last year
so I just thought....
1982 911SC
Old 02-15-2013, 07:18 PM
DWeg1998's Avatar
Don't know of the data to back him up, but a mechanic once told me that with synthetic oils and people that don't drive much he is seeing cheap filters go bad way before the oil goes bad.
Old 02-15-2013, 07:28 PM
Senior Advisor
James Brown's Avatar
here is a change, i change the filter every 3000 miles and the oil every 6000 miles or twice a year, there easy to change and you can cut open the old filter and look at what got trapped in the element. cheap, almost free piece of mind. P.S. never found anything in the filter, always clean. 4 filters a year and 24 quarts of oil, plan ahead now and stock up. one less thing to worry about, drive it
08 Cayenne Turbo
Old 02-15-2013, 07:31 PM
80-911SC's Avatar
you should not try to save a few dollars this way ....
buy a good quality filter and use good oil .... peace of mind as far as i am concerned ....
there are also other threads about if you can use delo or rotunda oil in the gallon size from a discount store ... and the answer is yes ... just like the answer to your question is yes YOU can ...
if YOU WOULD LIKE TO ... we are just giving you our opinion because you asked...
pelicans don't let pelicans do dumb stuff .....
if you have not looked into it ... take a look at the engine rebuild board ... do it your self rebuilds with machine shop and parts start at about 8000 then since your in there costs add to that running total .....
Steve....
order two filters ..........
Old 02-15-2013, 08:20 PM
Dave Colangelo's Avatar
I have heard that you can change the oil filter every other oil change but why risk it, especially with these cars the filter is cheap and easy to change just do it.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 02-15-2013, 09:16 PM
Porchcar guy's Avatar
Order the correct filter, take your trip, have fun, and change the oil after :=) Novel idea !!
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 02-15-2013, 09:47 PM
I always put a label on my oil filter with the date of the oil change and tyoe of oil. That's the only way I can remember when I changed the oil....So, a new filter is a must for me or it would ruin my system.
Old 02-15-2013, 10:10 PM
rnln's Avatar
Just take the filter off with full oil tank? Oil doesn't pour out?
Fat butt 911, 1987
Old 02-16-2013, 12:11 AM
Senior Advisor
no, oil is on the bottom of the tank pull your dip stick and place it in the normal location but on the outside of the tank, that is the level of the oil in the tank.
08 Cayenne Turbo
Old 02-16-2013, 12:26 AM
rnln's Avatar
You are right :lol:
Fat butt 911, 1987
Old 02-16-2013, 01:02 AM
That's a great idea. I need to find a white marker. On my Suburban I write the install date on new alternators, they last about 5-7 years. I nailed up a piece of paper in the garage with oil change info. on 3-4 cars. Too much to keep track of.
I change the filter every time also and use 15-40 BP, when I was going to the track I used 20-50.
Sold: 1989 3.2 coupe, 112k miles
Old 02-16-2013, 06:29 AM
Functionista
manbridge 74's Avatar
Change it for all the reasons listed above.
On engines that aren't worth much to me I've drained the filter by propping open the anti-drain back part. But these are engines that get run infrequently and it's not worth it on the P-car.
Old 02-16-2013, 07:04 AM
Besides cleaning the oil, my filter also keeps track for me (I do the same with the fuel filter). With more than one car, I can easily get mixed up:
Old 02-16-2013, 09:42 AM
AutoBahned
RWebb's Avatar
there are 2 issues here:
1. the tiny amt. of old used oil left in the filter (which will be swamped by the oil left in the cooler and lines, even if it was not dumped out)
2. a remote possibility that the filter will be gunked up by being used for an extended time, causing the bypass to open and unfiltered oil to flow thru the motor
#2 is unlikely and if it happens you have a serious problem in the engine anyway; filters with filtrate on them also filter more efficiently than new filters (something you can learn in your chemistry classes) so that idea is a non-issue
bottom line: no big deal
OTOH, why not change it?
Old 02-16-2013, 11:21 AM
