Whale tail and A/C - is there a mechanism here for air flow?
Guys,
Went to the shop to reload the a/c system with gas. The shop owner asked me if there was not suppose to be a closing system of some sort on the small "grill" opening on the whale tail. He claims that air will flow thru there because its easier, he imagined a system that opened and closed as the a/c is turned on/off so the air can be redirected to flow thru the larger "grill" (condenser) opening. Here are some pics:
From the top, the small at bottom of the pic and larger (condenser) at top:
Same one:
From inside, nothing there, free flow....
Another angle:
Old 02-16-2013, 01:51 PM
brads911sc's Avatar
your best bet is a fender condenser kit from Griffiths or ZIMS so as to minimize the extra heat in your engine bay...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 02-16-2013, 02:10 PM
kuehl's Avatar
Funky deck lid.
For the deck lid condenser to work effectively all the air moving through the engine deck lid "grills" should pass through the condenser. It would appear the odd second small grill opening would allow air to bypass the condenser opening, hence less air moving through the condenser... not good for a stock system.
Unless you have a good reason for the second grill opening I'd suggest blocking it off if you want AC.
Old 02-16-2013, 03:05 PM
