Hello Porsche guru's.
Okay so I got the car back with running ac. It's pretty poor with limited cooling and I'm thinking of asking the mechanic to upgrade the whole system. My issue is that the engine dies when cold when the AC is on. It is also is a bit difficult to start when cold. is this a sign of issues with the cis or does the idle just need to be turned up? or some other alternative? help please?
Johann 1986 911 Carrera [SOLD] 1980 911SC [SOLD] 2004 911 |
Also - has anybody installed the rennaire system listed by our host on a right hand drive car? are there issues that I need to be aware of prior to purchase?
Did the SC's do anything regarding fuel/timing for A/C? I know on the 3.2's the DME is aware of the A/C compressor running, and on newer cars they go one step further and the engine computer actually controls the compressor themselves, so they can bump timing/idle/etc BEFORE switching on the compressor.
If they don't compensate, you may need to bump your idle yourself to accomodate. However, reading your posts you seem to have another problem that affects the engine at all times, and the A/C compressor is just the last straw so to speak, and the additional load causes the engine to stall... sounds like you need more cold-start fuel. HTH, Chuck.H '89 TurboLookTarga, 345k miles |
Hi chuck,
Well I suspect it's AC related because if I switch the fan off, it seems to start okay and idle okay as well!
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Read the Mr. Ice Project |
Thanks Kuehl.
I guess they've put too much coolant in? I'm guessing having read your article. Given the refrigerant loss over time, does this mean that the RPM etc will return to normal over time? or will I need to take it back to get them to readjust? or reduce the amount of refrigerant? All this messing around is convincing me to upgrade the entire system. I suppose I should start with barrier hose? Is that what you would recommend I start with? Or are the losses so small that I would probably get more gains out of a new compressor? Your advice would be most appreciated.
Johann 1986 911 Carrera [SOLD] 1980 911SC [SOLD] 2004 911 Last edited by johann86911; 01-31-2013 at 12:56 AM.. Reason: additional questions |
"If" was the word.... if the system is overcharged or if the system pressures are too high....
I'd suggest having an independent Porsche shop check your system pressures at idle, deck lid down, windows up, thermostat max cold, fan speed 1 or 2, on a day when the outside (ambient) temp is at least 23C or higher. Your ac tech should be familiar with Pressure and Temperature charts. If the system pressure is too high for the ambient temp at the moment that will give him a clue as what to do next. Overcharged is simply a more common problem based on the symptom you noted.... rpms drop. There could be other issues but that is where you normally start with the diagnosis. Yes, a good set of barrier hoses will greatly reduce the most common cause of system leaks. However, if you have the gut feeling you need "some" good upgrades I would suggest you do them all at one time rather than piece meal ala carte the project as that road is always more expensive in the long run. You can do all of the parts replacement/upgrade work yourself and let an experienced AC tech handle the evacuation/charge/test later (its simply not cost effective to buy AC charging and testing equipment if you plan to do this job once & right the first time). Besides the barrier hoses there probably will be other upgrades you will need. Although historical climate in Melbourne averages 26C this time of year, the trend is upward and if plan to drive inland you will need more cooling capacity. So it comes down to this: How long do plan to keep the car, How often do you want to drive it, Is comfort critical to the ride. Once again you can do most of the work yourself. So, there are a handful of AC improvement sources out there, in alpha order: Griffiths, Rennaire, Retroaire, and naturally right here on Pelican you can buy some of their products. The choice is up to you. There are quite a few threads here in the 911 section of the forum discussing what works and what does not work. Off the top of my head I'd suggest reading posts by Jim Sims and mthomas58 , and there are plenty of other good ones. If you need more help just drop me a PM. Best regards from this side of the pond, Griff |
The factory A/C has just one major shortcoming, lack of sufficient condensing capacity. Add two 12 inch fans to force more airflow over/through the rear deck condensor when the engine RPM isn't enough and problem solved. Oh, sorry, not quite. Add a binary pressure switch to control the compressor to prevent it from producing system over-pressure and/or damaging the compressor should the refrigerant be to low. Or even better yet use a trinary switch, third element to run the fan, even with engine off, whenever the system pressure is above a preset level. And don't be overly surprised if this latter effort solves the issue of leakage due to non-barrier hoses. And please keep in mind, the proof is in the pudding, Kuehl will do, say anything he can to prevent you from trying a $100 solution when he would rather sell you a $1,000 plus solution. |
It seems to me Kuehl offers up some very good advice for cooling issues here and your shot at him is a tad less than gracious...
Gary R. |
It's OK.
Wwest keeps forgetting to take his meds. |
WWEST - LOL just LOL.
In some posts he admits they are actually $300 SPAL fans to get what he claims, then in others its $30 SPAL fans. Do a search. Its quite entertaining He even told a guy that he didnt need to replace leaking hoses but rather install the fans because R134a is so cheap... he actually claims that these SPAL fans solve ALL the shortcomings of the 911 AC system in one post. wow. good to know! LOL He is the resident guru on so many topics I lost track! yet real science and data proves him wrong over and over on every topic. he lives in an area where they dont even use AC. stick to the swamp cooler WWEST! if you want cold AC on a 95 degree day with 85% humidity, ignore anything he tells you. Kuehl on the other hand will deliver what he promises. Quote:
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 01-31-2013 at 11:48 AM.. |
Needlessly so, mostly, and at GREAT expense. Kuehl's product set, and air cooled 911 A/C system knowledge, is now more historic than otherwise. Take a look at how the water cooled Porsches SOLVE this very same problem, in SPADES. Electric fans are used to provide both engine cooling AND A/C refrigerant condensing. *** How can it be that those very same A/C refrigerant hoses were in use throughout the automotive A/C industry during the very selfsame period and yet only the Porsche 911 series suffered, consistently suffered, refrigerant leakage?? There are quite possibly 2 valid answers. 1.) Using ONLY the thermostatic switch to control the compressor clutch could have resulted in system overpressures beyond the O-ring sealed capability. 2.) An overpressure resulting from engien shutdown but with the condensor high side already at "maximum" pressure. No blower to pull cool air through the rear lid condensor and LOTS or convection heat from a still HOT engine now flowing upward through the rear lid condensor. Oh, and let's not forget that many owners of these air-cooled 911's swap out the engine fan in order to get more cooling at low engine RPM. The condensor cooling fans might very well accomplish that need just as well. Last edited by wwest; 01-31-2013 at 03:12 PM.. |
I have read a couple of posts saying don't talk about air conditioning or oil on this forum but wow!
So, further developments - I've discovered a couple of things which will hopefully assist all (including me)! 1. The car only stalls when I put the fan on the dash board and the fan associated with the AC on. If I only put the fan associated with the AC on, the car is fine. 2. when the car starts to move after being stationary, there is what sounds like a low grinding noise. So - I'm thinking compressor? AC blower motor? electrical gremlin? all three? On the whole - the system is operational if not super efficient, except for the above two issues. Thoughts/ suggestions would be most appreciated. Kuehl - funds wont extend far enough to a complete system just yet (although I must admit I am tempted). WWEST - I'm actually about 40 mins out of Melbourne but happy to meet for a chat/coffee.
B) If you want a/c the a/c system and only a/c air you do not need to move the slides in the dash. However, if the issue is happens with the a/c off and the fresh air motor on (top slide in the dash) the possibly its the circuit overloading on the fresh air motor. The fresh air motor consumes about 5 amps nominal. Where is the grinding noise specifically coming from? Are talking wheel bearing, brakes, tranny, brakes....? |
Its all in the eyes of the beholder. We all know you can't afford some things . Quote:
Don't think I said that but if I did it was mistaken. I have understood the Ops to mean they wished to have more cooling at low engine RPMs, more fan blades, pulley ratio to turn fan faster. Last edited by wwest; 02-06-2013 at 08:45 PM.. |
The rate of loss is relative to the amount of surface area. 911's have more a/c surface area because of the larger volume of hose; hence barrier hose reduces the permeation rate. Quote:
2) Amazingly the engine's heat dissipated up through the condenser does not raise the system pressures. If you feel strongly about your hypothesis you have been tossing in every a/c related thread here in the forums then maybe you can take the conjecture to a higher level (no pun) and present a video for us. Quote:
Once again. Make us video of your rising pressure concept. |
| Tags |
| air conditioner , rough idle |
