Removing center dash knobs/switches
I am trying to remove the knobs/switches on the center dash console of my 964 (IE fog lights, headlights, defroster, etc). Do these just push out or are they screwed in?
thanks. -Don |
Schleprock
You peel back the rubber surround and pull out the switch's symbol/cover plate. Then you should be able to see a nut that holds the knob on. Once you get the knob off, then there is a threaded disc (parts diagram calls it a rose) that you have to spin off with a pointed tool like a pick or an awl.
Kevin L '86 Carrera "Larry" |
That sounds a lot more complicated than removing most buttons, haha. I will have to be careful removing the rubber surround without damaging it then.
-Don |
