2.7 RS engine conversion cost?
Eagerly awaiting Wayne's new book. I am considering rebuilding my 2.7 and wonder what the difference in cost from a standard rebuild would be compared to an RS spec engine.
i.e. What is the standard (range) cost in rebuilding a stock 2.7 liter engine?
Shakenbake (Chris Baker) Need new toys 2001 VW Jetta VR6 2003 Sea Ray 200 Bow rider |
As far as I understand the cost is similar when doing it properly . However you will spend more money on cyl head match porting, camshafts , and even more for injection if you chose not to use webers. I may be wrong though since Ive personally never performed a R/S rebuild myself.
Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
The main difference between an RS engine and a regular 2.7 is the following:
S cams RS pistons/cylinders MFI Other than the above, your rebuild will follow the procedures for any other 911 engine. Hope this helps, Sherwood Lee http://members.rennlist.org/911pcars |
Guest
Posts: n/a
depending on your engine type, the intake and exhaust port may be different too.
drag racing the short bus
2.7 RS cost
I looked into this: the shop I dealt with asked about $2K more to rebuild my 2.7 and include the MFI system. You should also consider an extermal oil cooler if you don't have one already. I hear that's another $1,200 retail.
