Mo money = mo parts
Rear Shock Question - Gap Too Large?
I have had a clunk in my rear suspension and noticed I was getting a slight creak when I slowly raised the trailing arm with a floor jack. It disappeared when I disconnected the shock. I also noticed that prior to removing the shock mounting bolt and portion of shaft that protrudes into the engine compartment seemed to be raising quite a bit (1/4") to when I would slightly jack the trailing arm.
I pulled the shock out and the thing that seems odd to me is that when I assemble the rubber bushings and washers, that there is a good 1/8" gap because of the metal sleeve that fits between the upper washer and shock cover. Is this correct? Seems as though you should the bushings should sandwich together to pinch the body, but I doubt ![]()
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
ROW '78 911 Targa
How old and hard are the rubber bushings?
They look flat to me.
Mo money = mo parts
The bottom one is definitely compressed compared to the top. However, I sent them to Bilstein last winter to be rebuilt, so they were new last year. They can't have more than a few thousand miles on them.
French Import
I just installed the same shocks last weekend and the bushings were much thicker than yours
![]() If you cannot get new bushings I suspect you could cut a little bit of the tube that goes inside the bushes to compensate for the rubber compression.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
ROW '78 911 Targa
Banned
How long did it take you to train that albino chimpanzee to hold the parts for you?
Kurt |
Mo money = mo parts
Thanks Gilles, I suppose cutting the tube is a possibility. The shock has to be the source of my clunk. I re-installed the shock at the bottom, then set the washer on the top. The shock shaft prevents the washer from going down further, so this means that the top of the shaft never has a tight grip on the body. And in a tight turn when there is weight transfer and my clunk was occurring, I can see the top of the shaft bumping the shock tower.
I just ordered 4 new Porsche bushings from our host. They appear thicker in the photos than those that Bilstein sent, but pictures can be deceiving. I thought I was getting a deal having my shocks rebuilt. However, $65 each plus shipping both ways and now $15 for correct shock mount bushings. I'm sure I have $100 invested in each shock. My recommendation to anyone is unless you are doing custom valving....buy new.
Banned
Siber I can't agree with you more, I laughed my ass off
Ernie 81sc |
Second, Any time I've had my shocks revalved Bilstein never replaces the "external" pieces like your rubber bushings, just the internals. So I suspect you got back exactly what you sent them. You did the right thing ordering new bushings from our host. Could you have bought new shocks? Sure. Most of us use Bilsteins services when revalving shocks and at $65 each to revalve and essentially rebuild, so that's a real bargain. I bet your new bushings cure the problem
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
French Import
That is good info. As I never had my Bilstein rebuilt I didn't know that.
AutoBahned
custom valving should give different jounce & rebound than the off the shelf parts have
those look much older. than a couple years. when did the noise start? do the shock bodies show signs of rubbing?
Chuck Moreland - elephantracing.com - vonnen.com |
I don't know if it applies but I just had to change the Bilstein shocks on my truck after one year because the rubber bushings comepletely turned to junk. They warrantied them but I don't have high hopes for the replacements. Everything is crap today
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
Mo money = mo parts
![]() __________________________________________________ ____________________________________ Chuck - The bottom one was compressed, but the top one is the original shape and size when I installed it. You probably don't remember, but you gave me some help on this forum last February when I asked a question about trailing arm bushings that I purchased from you. The shocks were installed as part of that project. There wasn't excessive rubbing on the shock bodies, but since they were used it was a little hard to tell. Anyway, the noise was a "clunk" during hard cornering, not a constant rub. Thanks for everyone's help and comment.
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" Last edited by gregwils; 02-24-2013 at 08:45 AM.. |
Banned
Banned
