Mo money = mo parts
Rear Shock Question - Gap Too Large?
I have had a clunk in my rear suspension and noticed I was getting a slight creak when I slowly raised the trailing arm with a floor jack. It disappeared when I disconnected the shock. I also noticed that prior to removing the shock mounting bolt and portion of shaft that protrudes into the engine compartment seemed to be raising quite a bit (1/4") to when I would slightly jack the trailing arm.
I pulled the shock out and the thing that seems odd to me is that when I assemble the rubber bushings and washers, that there is a good 1/8" gap because of the metal sleeve that fits between the upper washer and shock cover.
Is this correct? Seems as though you should the bushings should sandwich together to pinch the body, but I doubt
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 02-23-2013, 06:43 AM
ROW '78 911 Targa
timmy2's Avatar
How old and hard are the rubber bushings?
They look flat to me.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-23-2013, 06:56 AM
Mo money = mo parts
The bottom one is definitely compressed compared to the top. However, I sent them to Bilstein last winter to be rebuilt, so they were new last year. They can't have more than a few thousand miles on them.
Greg
Old 02-23-2013, 06:59 AM
French Import
zippy_gg's Avatar
I just installed the same shocks last weekend and the bushings were much thicker than yours
If you cannot get new bushings I suspect you could cut a little bit of the tube that goes inside the bushes to compensate for the rubber compression.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 02-23-2013, 07:07 AM
ROW '78 911 Targa
timmy2's Avatar
Pelican Parts - Product Information: 911-333-521-00-OEM
These look a lot thicker.
Dennis
Old 02-23-2013, 07:24 AM
Banned
How long did it take you to train that albino chimpanzee to hold the parts for you?
Old 02-23-2013, 07:26 AM
KNS KNS is offline
Nice contribution...
Kurt
Old 02-23-2013, 07:34 AM
Mo money = mo parts
Thanks Gilles, I suppose cutting the tube is a possibility. The shock has to be the source of my clunk. I re-installed the shock at the bottom, then set the washer on the top. The shock shaft prevents the washer from going down further, so this means that the top of the shaft never has a tight grip on the body. And in a tight turn when there is weight transfer and my clunk was occurring, I can see the top of the shaft bumping the shock tower.
I just ordered 4 new Porsche bushings from our host. They appear thicker in the photos than those that Bilstein sent, but pictures can be deceiving.
I thought I was getting a deal having my shocks rebuilt. However, $65 each plus shipping both ways and now $15 for correct shock mount bushings. I'm sure I have $100 invested in each shock. My recommendation to anyone is unless you are doing custom valving....buy new.
Greg
Old 02-23-2013, 07:36 AM
Banned
Wow.
Does life *really* need to be so damn serious all the time? Or is it particular to this forum that some folks are humor-impaired?
Old 02-23-2013, 07:54 AM
emac's Avatar
Siber I can't agree with you more, I laughed my ass off
Ernie 81sc
Old 02-23-2013, 09:25 AM
175K911's Avatar
First, don't cut the tube, it's not the problem.
Second, Any time I've had my shocks revalved Bilstein never replaces the "external" pieces like your rubber bushings, just the internals. So I suspect you got back exactly what you sent them.
You did the right thing ordering new bushings from our host. Could you have bought new shocks? Sure. Most of us use Bilsteins services when revalving shocks and at $65 each to revalve and essentially rebuild, so that's a real bargain.
I bet your new bushings cure the problem
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 02-23-2013, 09:44 AM
French Import
zippy_gg's Avatar
That is good info. As I never had my Bilstein rebuilt I didn't know that.
Gilles & Kathy
Old 02-23-2013, 09:52 AM
AutoBahned
RWebb's Avatar
custom valving should give different jounce & rebound than the off the shelf parts have
Old 02-23-2013, 12:21 PM
Chuck Moreland's Avatar
those look much older. than a couple years. when did the noise start? do the shock bodies show signs of rubbing?
Chuck Moreland - elephantracing.com - vonnen.com
Old 02-23-2013, 12:32 PM
I don't know if it applies but I just had to change the Bilstein shocks on my truck after one year because the rubber bushings comepletely turned to junk. They warrantied them but I don't have high hopes for the replacements. Everything is crap today
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 02-23-2013, 01:29 PM
Mo money = mo parts
Not long, about the same amount of time it took him to learn to recognize a 'dick head' when he sees one.
__________________________________________________ ____________________________________
Chuck - The bottom one was compressed, but the top one is the original shape and size when I installed it. You probably don't remember, but you gave me some help on this forum last February when I asked a question about trailing arm bushings that I purchased from you. The shocks were installed as part of that project.
There wasn't excessive rubbing on the shock bodies, but since they were used it was a little hard to tell. Anyway, the noise was a "clunk" during hard cornering, not a constant rub.
Thanks for everyone's help and comment.
Greg
Old 02-24-2013, 04:15 AM
Banned
Not long, about the same about of time it took him to learn to recognize a 'dick head' when he sees one.
OK, the first comment made me LOL, but that reply is outstanding. [bows to Greg]
Old 02-24-2013, 07:34 AM
Banned
Ha!
Old 02-24-2013, 08:12 AM
