faverymi's Avatar
Fleabay your best best.
Name for them:
Hemostats, Needle holders, Sterilizations picks(bigger ones)
Hu-friedy, aesculap, SS white, miltex. Some of the better brands, really better quality steel.
Types
Kelly (like scissors) Castroviejo (you squeeze them with your whole hand), Mosquito (small )
That's off the top of my head.
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 02-24-2013, 11:28 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by faverymi View Post
...........miltex..........
This is my kind of thread. Check these bad boys out. They must have been designed by H R Giger.
Some say Giger used sexual references in his art. I sure can't see any.
1981 911SC Targa
Old 02-24-2013, 12:03 PM
Originally Posted by wacko View Post
Have read in a few other threads about using locking forceps to install new hood struts.
LOL. There are some jobs in the trunk or under the dash that are really awkward, mostly because of access. But the locking clips on the hood struts really didn't seem that hard when I did them. Just line everything up and push the clips on with long-nose pliers.
'77 S with '78 930 power and a few other things.
Old 02-24-2013, 12:04 PM
Another option for forceps.
McMaster-Carr Forceps
Old 02-26-2013, 07:56 AM
m110's Avatar
Originally Posted by Bob Kontak View Post
I think the forceps can have locks as well. Assuming the thingies with loops at the tips are forceps.
Forceps are any grasping tool. They can be tweezer like (Adson forceps) or plier-like for holding a sponge like the Foerster at the top.
Hemostats are a variety of forceps that lock and are used to control arterial bleeding among other things. They come in different shapes and sizes with a Kelly being a nice curve with taper and teeth and useful for cars. The lower clamp is a little bigger and is called a Mayo. I use one like that to gently clamp off fuel or vacuum lines.
1988 Carrera Coupe
Old 02-27-2013, 11:00 PM
tazzieman's Avatar
Bad boys? You want bad boys? Or tools for pulling out bad boys that get stuck at source? Here you are you sick puppy
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 02-28-2013, 02:50 AM
Buy Forceps
I buy multiple types of forceps from GerMedUSA.
Old 01-13-2025, 01:42 AM
PCA Member since 1988
Ancient thread.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-13-2025, 01:55 AM
sean m's Avatar
Bass Pro Shop in the trout fishing area........
Sean M
'77 911S Targa Ice Green
Old 01-13-2025, 06:42 AM
