Hunt3R's Avatar
Question Replacing bad starter, only 1 yellow wire connected?
My starter is dying on my 86 Carrera so I was following this tech article about replacing it: Pelican Technical Article: 911 Starter Installation.
And it says I should have 2 yellow wires connected to the spade terminals: "The larger (2.5mm) yellow wire carries the control signal from the ignition switch. The smaller yellow wire (.5mm, may also have a colored stripe) activates the cold-start injector when the starter is engaged."
The bad starter solenoid does have a bottom terminal but there was nothing connected to it and I only have 1 yellow wire that was connected to the top spade terminal. Is this to be expected? The tech article was written for an SC, maybe something changed by '86? Here's all I see there after removing the starter
I think the solenoid is bad because cranking voltage to the solenoid output terminal was a couple volts low and sometimes the car just won't even try to crank. Other times it'll start right up, seems to be getting worse though.
I already ordered the high torque starter from our host and should have it in a couple days but it didn't say anything about them accepting a core charge for returning the old starter, can I return it to Pelican for some money? I'd hate to throw it in the garbage if it can be rebuilt...
Old 02-24-2013, 03:33 PM
ROW '78 911 Targa
timmy2's Avatar
Your car doesn't happen to have fuel injection does it?
No CSV after CIS, no yellow wire needed.
That starter has a label saying remanufactured, Send it in for re-remanufacturing?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-24-2013, 04:21 PM
Yes and Yes - CIS has a cold-start valve (CSV). Motronic (84-on) doesn't.
'77 S with '78 930 power and a few other things.
Old 02-24-2013, 04:22 PM
Hunt3R's Avatar
Ah. I read CSV and thought ICV. Thanks.
Old 02-24-2013, 05:09 PM
