Caveman Hammer Mechanic
ClickClickBoom's Avatar
3.2 Operating temp?
Ok,
I will ask what temps are the 3.2 operators getting here? I converted my '84 to the '75 oil temp gauge set up including the proper '75 sender. Gauge temps were verified with the very same IR remote thermometer that was used on my dogs butt so I know its good to go! The gauge was within a very small margin of error using the IR thermometer. I temped the oil filter, oil tank, engine case at the temp sensor location and the dogs butt for calibration purposes. All temps were very close except the dogs butt! With an outside temp of 60 deg F, I only get to 180 degrees after driving hard and on a down hill the temp will drop to the 120-130 range. I replaced the engine thermostat after confirming the hot water test to confirm correct operation and the original thermostat worked fine as well.
Is this engine just a cool runner?
eric
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 02-26-2013, 11:54 AM
Member 911 Anonymous
DRACO A5OG's Avatar
194 is the norm but with cooltemps it will stay around 180, but in traffic you will see it go to 194+
'85 Carrera Targa
PCA/POC
Old 02-26-2013, 12:06 PM
Last summer I was worried about my engine running cold so I did the same things with an IR thermometer. I don't have a dog so I had to use my own butt for calibration. I was told that 180F is the middle of the Carrera temp guage and is, more or less, considered the normal operating temperature. My guage was showing cooler, but the (carefully calibrated) IR remote showed 179F at the valve covers. Rather than have the engine rebuilt, I've decided to accept that it runs one degree cold.
Sounds like yours is indeed running a bit cold though. Seems like you've tackled all the things I would have recommended, except maybe switching to a less viscous oil. 10W-40?
1987 Targa Indian Red
2001 Volks Jetta (winter beater)
E Sully's Avatar
When I had an '86 engine in my 1973, I had installed external oil cooler lines and trombone cooler. At 60 deg temps it would stay around 170- 180 degrees. In the summer it would run around 180 most of the time, maybe reach 200 when sitting in traffic. No a/c car. After warm up it did not drop down to the 120's you're seeing.
Ed
1973.5 T
Old 02-26-2013, 12:14 PM
db_cooper's Avatar
Bend your head to the right of the steering wheel, turn left, there usually numbers under the bezel. They are in centigrade.
Thanks to Joe Bob in the thread below. Lots of cool running 911s this time of year.
You can increase the winter engine temps by running the A/C on a low fan setting with the heat on. It will warm the rear condenser air flow to the engine.
Not much use below freezing..but works when it is 40*/50* outside and you want to get your oil temps up faster.
Temp/pressure gauge
Old 02-26-2013, 12:20 PM
This is a flick of the gauge when it was in the '75:
Trying to get an handle on a new model engine!
Old 02-26-2013, 12:55 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Oil Temps.
185-210F is the optimum range.
210F to boil off some of the condensation in the oil.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 02-26-2013, 02:25 PM
kodioneill's Avatar
Mine runs 180 (eight o clock) spring and fall then 210 (845- 9 o clock) in the summer.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-26-2013, 02:39 PM
1984 Targa Carrera
I know there are no stupid questions, but this is a stupid question. When the oil temp gauge has no numbers on it, what temperature does the lines on the gauge equate to?
1984 Carrera Targa
Old 07-02-2013, 02:23 PM
RETIRED
Joe Bob's Avatar
The engine runs at what the thermostat opens at. It climbs past that when driving conditions exceed the coolers capacity.
2012 ML350 3.0 Turbo Diesel
Old 07-02-2013, 02:44 PM
Reiver
Reiver's Avatar
on an SC or 3.2 9 o'clock is about 230
Old 07-02-2013, 03:36 PM
sky1jord's Avatar
I think, but not sure, that this came from another Pelican thread
Old 07-02-2013, 11:32 PM
BW
ruwoodbury's Avatar
If 9 o'clock is half-way between the 194 and 248 marks that's actually 221f. My car has been running warm recently (230-250f) so I had the internal thermostat tested. It wasn't opening until 250f!! With a new thermostat in the oil temp is now running 210-220f in outside temps of 95-100 with the a/c running.
BW
1989 Carrera--Rebel Racing Suspension, Patrick Motorsports LtWt Clutch Assembly, Enlarged TB, 964 Cams, SSI, Dansk Sport 2-in-1-out, SW Custom Chip, Turbo Tie Rods, Bump Steer Kit, H4s, Vintage Seats RS Replicas, RS Door Cards--and some other stuff
Old 07-03-2013, 06:22 AM
1984 Targa Carrera
Thank you. Mine runs below 9:00! Probably between 8:30 and 8:45 which sounds about normal.
1984 Carrera Targa
Old 07-03-2013, 06:24 AM
These guys use to sell overlays I installed them in my car awhile back.
http://newvintageusa.com/911modules
Old 07-03-2013, 01:01 PM
Reiver
Reiver's Avatar
9 o'clock is more than half way...it is at the unnumbered small tic mark which is actually an alignment mark for mounting the scale. Closer to 230 than 220.
The picture of the gauge above is slightly canted.
Old 07-03-2013, 01:21 PM
Rescuer of old cars
Arne2's Avatar
911 Gauge module overlays
I've wanted to add one of their numbered overlays to my gauge, but I dislike using Fahrenheit scale in a German car. I'm talking with them now about the same overlay but in Celsius. Might have to have a batch of 10-12 made. So if I do it, I'll have some spares to sell.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 07-03-2013, 02:09 PM
theclaw's Avatar
Sub'd since I have a couple of small dents in my oil lines and wanted to keep an eye on things. Couple weeks ago I was up to the second mark after a track session.
'84 Carrera (recently sold )
'67 MB 250SL
A few Italian motorcycles
......and a minivan for the crew
Old 07-03-2013, 02:51 PM
theclaw's Avatar
This for 3.2s?
'67 MB 250SL
Old 07-03-2013, 03:30 PM
RETIRED
Joe Bob's Avatar
That scale isn't accurate for all 911s.....
Old 07-03-2013, 04:09 PM
