I didn't as well! But I have to say that I am very pleased with the result.
Concerning the brake system, I will have a servo assisted system as the car is supposed to be used in tarmac with rear refurbished standard 3.2 calipers and front four piston Brembo calipers: http://forums.pelicanparts.com/uploa...1363465789.jpg |
Finally I got it at my garage! The fun will start now!
http://forums.pelicanparts.com/uploa...1364979987.jpg http://forums.pelicanparts.com/uploa...1364980034.jpg |
Started with the front and rear suspension and steering.
Alignment kit for the steering rack installed: http://forums.pelicanparts.com/uploa...1364980136.jpg New front sway bar: http://forums.pelicanparts.com/uploa...1364980226.jpg |
Shocks are Bilstein, re-valved for tarmac rally use.
The original suspension configuration will be kept but upgraded with new hard bushes and bigger torsion bars. At the rear suspension, mono-balls were fitted: http://forums.pelicanparts.com/uploa...1364999268.jpg http://forums.pelicanparts.com/uploa...1364999332.jpg |
Subscribed.
Love to see this build here Alex. Makes my RallyCross (USA) build seem somewhat pathetic. Keep posting, the more details the better. What do you have planned for wheels? Sen. Sainz is using our BRAID BZ. Give my amigo Evandro a call there. He'll take care of you. He's from Portugal too. SmileWavy Good luck. |
re: duck tail, how fast will your rally be?
also, are you worried about collecting rust-promoting debris in the gaps for the torsion bar weld-ups? |
I am planning to buy some Braid (16x7 + 16x8). I cannot buy it now but latter I will do it. I also saw Sainz on the classic rally - Nice car and nice result for Porsche! I will contact Evandro when I contaçt Braid. Many thanks for he suggestion. |
Regarding your second comment, (Sorry for my por English), I believe you are talking about the weldings around the threads on the torsion bar tube... (???). All the weldings were done for stiffening purposes, if that is what you talking about... |
yes, the welded pieces - dirt & debris can get in those cracks, so you might want to stick some sealer in there
Also started to assemble the brake system and pedal box:
http://forums.pelicanparts.com/uploa...1364999489.jpg http://forums.pelicanparts.com/uploa...1364999547.jpg |
At the same time, I have to say that after each event the cars are washed and dry with blown air to clean every dirt and grease on the chassis. In my opinion, following this procedure on each event, I prevent a lot o future trouble. |
definitely a good idea - we will all look forward to seeing some pics of the car in full flight
Meanwhile, this project had to slow down a bit, because I had to finish another car that is already sold.
A few little developments: Gear stick from Wevo is already installed... http://forums.pelicanparts.com/uploa...1373870708.jpg |
Did some test with he bucket seats... Amazing how they make the cockpit smaller when inside the car...
http://forums.pelicanparts.com/uploa...1373871136.jpg |
.... another one....http://forums.pelicanparts.com/uploa...1373871178.jpg
Parts that I already received....
The short gear kit: http://forums.pelicanparts.com/uploa...1373872500.jpg : |
Special clutch disc (Helix) and Sachs Motorsports pressure plate:
http://forums.pelicanparts.com/uploa...1373874300.jpg http://forums.pelicanparts.com/uploa...1373876622.jpg |
| All times are GMT -8. The time now is 02:31 AM. |
