-   -   The build of a rally car - tarmac, open Class (http://forums.pelicanparts.com/porsche-911-technical-forum/736277-build-rally-car-tarmac-open-class.html)
AlexJ 07-15-2013 01:27 AM
Steering is assembled...
http://forums.pelicanparts.com/uploa...1373876798.jpg
AlexJ 07-15-2013 01:29 AM
Front and rear brakes (not finished)...
http://forums.pelicanparts.com/uploa...1373876907.jpg
http://forums.pelicanparts.com/uploa...1373876956.jpg
andy_uranium 07-15-2013 03:50 AM
Looks amazing! Subbed for future progress, keep it coming.
AlexJ 12-16-2013 12:01 PM
A few more developments on this project.
An issue with the brake upgrade that was supposed to be a bolt in solution, needed up being a time waster while other things could have been assembled...
Never mind...
Basically some more interior had been assembled.
http://forums.pelicanparts.com/uploa...1387223961.jpg
Working with the fiberglass panel for the dash top, was a terrible experience. At the end we manage to find a way to attach it
http://forums.pelicanparts.com/uploa...1387224085.jpg
AlexJ 12-16-2013 12:08 PM
The hole fire extinguisher system is finished (not yet when the photos were taken).
http://forums.pelicanparts.com/uploa...1387224262.jpg
http://forums.pelicanparts.com/uploa...1387224307.jpg
Also the braKe lines are all installed, as well as the hydraulic hand brake.
http://forums.pelicanparts.com/uploa...1387224487.jpg
AlexJ 12-16-2013 12:11 PM
Still a long way to go...
http://forums.pelicanparts.com/uploa...1387224686.jpg
AlexJ 01-05-2014 03:00 AM
Working with fiberglass was not a pleasant experience... But for the first time, the final result was not so bad...
http://forums.pelicanparts.com/uploa...1388919439.jpg
http://forums.pelicanparts.com/uploa...1388919587.jpg
AlexJ 01-05-2014 03:02 AM
Doors are almost done...
http://forums.pelicanparts.com/uploa...1388919692.jpg
http://forums.pelicanparts.com/uploa...1388919732.jpg
Door top trim had to be modified because of the roll-cage.
kiwiokie 01-05-2014 08:04 AM
Wow that is looking really impressive Alex!
JohnJL 01-05-2014 03:10 PM
very nice, keep posting progress!
gearya 01-05-2014 03:38 PM
I'm curious about your painting on the bottom.
Since it will be hit by lots of rocks did you use an epoxy paint?
Or powder coating? I've heard that powder coating is hard but chips and is then difficult to repair.
What went into your thinking on the paint or treatment for the bottom of the car?
AlexJ 01-07-2014 12:43 AM
Thank you all for your comments.
Gearya, this is a car to be used in tarmac. In tarmac rallys there is not so much agression from rocks or dust.
The bottom was painted with a black chassis paint for extra protection, over epoxy paint. All the rest was painted with normal paint including the wheel arches where I like to show all the reinforcements done.
AlexJ 01-13-2014 03:28 AM
Doors ready. Very pleased with the result
http://forums.pelicanparts.com/uploa...1389612486.jpg
paul284pt 01-13-2014 04:51 AM
This is really impressive SmileWavy
Geat work Alex, keep the posts coming.
Good luck,
Paul
AlexJ 01-13-2014 11:33 AM
Thanks Paul!
AlexJ 01-17-2014 02:38 AM
New Mocal oil cooler already in place:
http://forums.pelicanparts.com/uploa...1389955046.jpg
AlexJ 01-17-2014 02:40 AM
I had to build new supports and brackets for the new cooler.
All built in aluminum and protected with powder coat.
http://forums.pelicanparts.com/uploa...1389955232.jpg
AlexJ 01-17-2014 02:42 AM
On this group of parts, also the coil bracket to install it on engine compartement:
http://forums.pelicanparts.com/uploa...1389955346.jpg
Flat6Heaven 01-19-2014 11:06 PM
Inspiring work Alex!
Is that a Ford EDIS coilpack? Also, are you going with the D-Zug / Kosmal EFI ITB setup?
Thanks for sharing!!!
AlexJ 01-19-2014 11:51 PM
Hi flat6heaven,
Yes, Dzug/Kosmal set up. Ford coil.
