Fuel Hose Type for Current Fuels?
We are looking at getting 3.2 engine area fuel lines rebuilt locally, being unable to interest a company in Florida to provide this service.
What type of fuel line should be used?
I read a bit and (PTFE) type hose is recommended in a Hot Rod 2011 article.
It seems that gasoline is not what it used to be.
Advice and specific make and model number specifications are welcome.
Thanks.
Sold: 1989 3.2 coupe, 112k miles
Old 01-30-2013, 08:52 AM
Senior Advisor
James Brown's Avatar
i used parker 5/16th USCG approved fuel hose. it is lined with impermeable plastic to prevent any fuel from leaching through the hose. available in many sizes.
08 Cayenne Turbo
Old 01-30-2013, 10:19 AM
Project Addicted
Look up Gates Barricade hose for fuel injection systems. It should me the SAE J30R9 for pressure.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 01-30-2013, 12:27 PM
AutoBahned
RWebb's Avatar
Gates Barricade - search here or OT for pics, more info
Old 01-30-2013, 01:34 PM
Thanks for the replies.
I looked at info. on the Gates Barricade, seems to be exactly what is needed.
Pelican comes through again.
Old 01-31-2013, 06:42 AM
Project Addicted
Be careful with what crimp bands are used. Some are too long and will actually cut the interior of the hose. If you use screw type clamps, just make sure to use the fuel injection type that have a more full circle clamp.
Jon
1966 912
1986 944
Old 01-31-2013, 05:32 PM
AutoBahned
RWebb's Avatar
BMW dealers have screw clamps that will not cut into the hose
Old 01-31-2013, 05:42 PM
SchnellSchweitz's Avatar
Barricade did not look like it offered the same protection as Teflon. I went with 6an steel braided PTFE myself.
I never smell gas now.
'82 SC 3.0L Targa, Chiffon/Brown
“It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche
Old 01-31-2013, 07:10 PM
Wew Wew is offline
SC Mutt
Wew's Avatar
I am with James on this one. I need to change all my fuel lines from fuel filter to fuel distributor and to each injector. Is what James mentioned applicable for all of the applications?
Thank in advance
Gary
1978 911 sc cal targa
Old 01-31-2013, 10:16 PM
Senior Advisor
Thank in advance
Gary
try to find the 80-82 steel lines from the fuel distributor to the injectors. all the fuel lines on a 78 CSI is going to be a tough one, many small hoses with strange bends and propriety fittings. the fuel tank to the fuel filter is straight forward
08 Cayenne Turbo
Old 01-31-2013, 11:10 PM
kuehl's Avatar
Sae j30r9
Old 02-01-2013, 06:21 AM
Goodyear has some SAE J30R9 hose.
After all this, last night we get a reply from the place in Florida informing that they will take on the job, it seems the contact info. was misplaced. So the 3.2 fuel line set will go there for rebuilding. They use a PTFE hose.
Old 02-01-2013, 06:48 AM
Project Addicted
I save threads that I think I might need down the like in Evernote. Superb software!!
Read thru this and make sure they use the right type of collars:
New fuel hose busted-fire narrowly averted
I looked at the USCG rated hose but it didn't meet the SAE J30R9 hose spec for pressure rating. It was rated as a fuel feed hose or vent line, not for the high pressure side of the FI system.
Jon
1966 912
1986 944
Old 02-01-2013, 06:59 AM
E Sully's Avatar
WEW,
If you ae looking to replace the pressurized cis nylon lines you must get the correct type. If the lines are not correct they will flex with pressure and affect the injectors. In this thread I got the correct lines from Verell@unobtainiumsupply.com
CIS Fuel Lines
Ed
1973.5 T
Old 02-01-2013, 07:13 AM
AutoBahned
RWebb's Avatar
the new Gates appears to be better than the Goodyear hose - I'm sure they will modify their products
talk to Boxster GT for more info if you need some custom hose/lines made up
I have seen people who are devotees of the crimp type clamps and others who belong to the screw type clamp camp. Not sure if it is just a religious affiliation or what their reasons are...
Old 02-01-2013, 01:53 PM
Discseven's Avatar
Just got petro rated hose and the clamps to redo '80 tank connections from Amazon Hose & Rubber Co here in Miami... total: $22.
Old 02-03-2013, 05:32 AM
BoxsterGT's Avatar
Porsche Crest
For Fuel Hoses, the best stuff out of Germany is DIN 73379-3E.
It is a Low Permeation, Multi-Fuel hose with an ECO abrasion resistant outer layer and aramid braiding inside.
This is rated for fuels up to and including E-85.
I import this in bulk to make my Porsche fuel hose assys. I can offer this in lengths up to 20 meters.
Please email me for details.
Len
Old 02-06-2013, 07:50 AM
onboost's Avatar
Len,
Wanted to follow up about fuel hose for the SC.. payment sent.. for zinc style hose as pictured,,
Thanks for your help..
Paul-
RGruppe #180
Old 03-03-2013, 01:21 PM
AutoBahned
RWebb's Avatar
those clamps look like the ones that cut into the hose and cause fires...
I'd use Norma type clamps
Old 03-03-2013, 01:51 PM
