Power window problem 81 911 sc RS door panel install
When I was changing the driver side door panel I made a mistake hooking up my window switches. When I tried to use the switch I heard a pop. I blew the 25A power window fuse, oops. I replaced the fuse and I want to sort out my window switch but it doesn't have power. What should my next move be? Relay? Thanks.
Old 03-05-2013, 11:20 AM
I did the same thing, so don't feel bad
Search for window switch wiring there is a post out there that has the correct wiring info in a couple of pics
Thats how I fixed mine
gone 82 928 Comp pkg 83 911 SC RS
69 911 T lightweight canyon carver outlaw soon
Lotsa Ducati's
99 Triumph 995i track bike
www.porscheresto.com
Old 03-05-2013, 11:40 AM
Here is the link
Ugh... drivers side window switches.
the wire colors were a little off for my 83 but by process of elimination of the ones that are correct you can figure it out
Lotsa Ducati's
Old 03-05-2013, 11:43 AM
Awesome! Thanks for your help ThomO.
Old 03-05-2013, 12:04 PM
yeah deffinatly dont feel bad. i did the same thing....4 times. i guess this now give me a reason to update to the newer style fuses.
Ryan- Sad day when my 83 911 left me
Old 03-05-2013, 12:27 PM
I still cannot get power to the switches. Would the next step be to replace the relay? Thanks.
Old 03-07-2013, 08:38 AM
I wouldnt think a relay would be hold you up in this case. are you sure you got the connections correct and replace with the correct size fuse?
Old 03-07-2013, 10:21 AM
TibetanT's Avatar
You probably need new switches now.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 03-07-2013, 11:10 PM
I think I have the wires correct but im not 100%. I will try to rearrange them and see if it makes a difference. If they are wrong, it should just blow the fuse again right? Yes, I did replace the blown fuse with the right fuse and I got a couple extra just in case it happened again. Thanks.
Old 03-08-2013, 11:11 AM
yeah itll pop them again if you have them incorrect. this is per the bently manual.
on the drivers door:
left window switch right window switch
1 blue red/ white
2 blue/ black red/ black
3 single red/ blue single red/ blue
4 brown brown
5 double red/ blue double red/ blue
Passenger door
1 blue
2 blue/ black
3 red/ white
4 brown
5 red/black
Old 03-08-2013, 11:26 AM
Topless crazy
seanratpel's Avatar
Winered : went through same problem as you (83sc) pass side switch, blowing fuses....finally popped off pass switch on drivers side looked at connections and repeated on other switch, no problems!!
Old 03-08-2013, 11:49 AM
