-   -   17" Fuchs (r) (http://forums.pelicanparts.com/porsche-911-technical-forum/738080-17-fuchs-r.html)
fl763 06-02-2013 11:26 AM
Wide body 78sc turbo flares
I used 8 and 9" combo, requires a 1" spacer up front and 2" in back. Maybe no spacer on later wide body. Hope this helps.http://forums.pelicanparts.com/uploa...1370201184.jpg
DRACO A5OG 06-02-2013 11:30 AM
Sweet :D
911GT2 06-02-2013 02:14 PM
Thanks!
DRACO A5OG 06-02-2013 03:54 PM
Centers and Support from Pelicans...
911GT2 06-02-2013 04:19 PM
I only found 17X7 and 17X9, where can I find 17X8?
fl763 06-03-2013 06:39 AM
First I need to apologize to our host, these came from Automotion. I bought them during one of the 20% off deals and paid just over 600 bucks for the set of 4.
They have 7,8 and 9 inch by 17. The only disappointment is the machining or casting ridges in the lips. There are fine grooves that you can feel more than see that go around the whole silver lip area. I saw a post from someone that said they sanded then polished out the grooves. I may tackle that one day. Paul from Braid Wheels said they will be producing 11X17's as well. If I had known I would have waited for the 11's with zero offset. I may still buy the 11's then I will have to sand and polish out the grooves. Hope this helps.
JTL 06-03-2013 08:20 AM
Thanks For Posting
I was thinking about going with the same setup. My car currently has a set of cup 1s for street use. The wheels look good but are pretty heavy overall. This may be a good time for a switch since the rear tyres need replacement soon.
testa-rossa 06-03-2013 09:24 AM
Just put these on:
http://i1272.photobucket.com/albums/...ps85a7bb2c.jpg
DRACO A5OG 06-03-2013 11:48 AM
Sweet :D
Hydrocket 06-03-2013 08:11 PM
Mine...
http://img.tapatalk.com/d/13/06/04/7adateme.jpg
JQ911 06-03-2013 08:37 PM
http://forums.pelicanparts.com/uploa...1370320526.jpg
Hydrocket 06-03-2013 08:46 PM
^^nice!!
carl74344 07-07-2013 06:28 PM
before....http://forums.pelicanparts.com/uploa...1373250421.jpg
after....http://forums.pelicanparts.com/uploa...1373250455.jpg
now new suspension and lowering.
djwhite 07-07-2013 10:08 PM
Originally Posted by Hydrocket (Post 7343125)
I weighed my OEM 16" with tires. My new tires come in tomorrow, so I'll be sure to post up before/after weights to compare 16" vs. 17".
Did you ever weigh the new ones??
KBOUSTANI 08-05-2013 04:17 PM
what is your ride height
Jandy911 08-10-2013 01:08 PM
Rota Fuchs! :)
http://forums.pelicanparts.com/uploa...1376168919.jpg
Eric Hahl 08-10-2013 03:15 PM
I refinished my Euromeisters to a brushed (kind of RSR) style.
http://forums.pelicanparts.com/uploa...1376176522.jpg
JQ911 08-10-2013 04:46 PM
nice one Eric! I was thinking of doing mine too (Rotas) on frosted RSR finish. Yours look sweet!
trader220 08-10-2013 06:55 PM
Eric, what process did you use to get that look on the euro's ?
lsf911 08-10-2013 07:04 PM
Eric,
Those look great! I have been waiting 4 months for my RSR Rota's. I hope they look that good when I get them. If I ever get them....
