Wire running across top of window frame under targa seal
Im just in the process of replacing my targa seal with a new dan the man version.
I have found a wire running under the seal that is glued all the way across the top of the window frame, in the targa seal channel. Its just got dark so I didnt have much time for investigation. Presume its for the heat sensor that sits bang in the center. My concern is that it will stop the new targa seal from sitting properly. What is its purpose would like to remove it. Cheers Ed |
Member 911 Anonymous
Please post a pic during the day, if you are talking about the windshield front seal, there should not be a wire of anykind in the channel.
If on the Targa bar, also none.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
If it is a light grey (almost white) single wire, then it is probably for the interior sensor for the automatic heat control, if your car has that option. Remove the wire and the controller won't work.
JR |
As Draco said, there should be no wire under that seal. Javadog is correct that the autoheat thermostat runs under the vinyl on the inside of the car in that same area. If I had to guess, I'd say someone bought a replacement windshield without an integrated antenna, and then hid one under the seal.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current) 1989 911 Targa (sold) 1996 993 Cab. (sold) 1999 x2 Boxster (sold) 2006 Cayman S (my daily) |
911 + 129 = JOB
Does it look like a telephone cord? Hardwire for a Valentine 1?
1989 911 Carrera Coupe 3.2 2012 BMW 135i M Sport "It is not how much power you have, it is how much you have left to spare!" |
Hmmm interesting.
I do have one of those sensors just by the rear view mirror, but on first view doesnt look like its attatched to that. I wouldnt be suprised if its a part of the aerial. Will investigate more / take picture tonight. Sydney time. Work is so inconvenient. Ed |
damn bills
Mystery wire ran across the window frame and ended both sides. Glued in place probably as part of an old aerial. Case closed. Wire removed.
