Norm Faustino's Avatar
freshening up my transaxle Should I reseal it too?
So I am in the process of painting the transaxle on my 78 sc but this is not only for cosmetic reasons but to prevent any further pitting which was severe in some spots. It sits here with a fresh coat of sealer/primer. I am getting ready to change the shift shaft and output flange seals and my question to you guys is should I split it apart and replace the case seals as well?
78 911 SC "Scratchy"
2004 Mini Cooper S "Pele" (gone but not forgotten)
1979 classic mini clubman-"Coolio"
Old 03-14-2013, 07:34 PM
Guardsred911's Avatar
Did it leak before? if not, I would leave it, personally...
J
911 SC - 1980
911 S - 1977
Old 03-14-2013, 08:56 PM
No,no leaks at all. And I was thinking the same as you if it ain't broke?... blah blah
but it is out of the car and I will be flushing it so maybe it could use a new set of gaskets. Oh screw it! I'll take my chances.
Old 03-14-2013, 11:18 PM
Without disassembling a lot of stuff, you can really change the shift shaft seal and the nose gasket. Not really worth it if it is not leaking. Why tempt the car God?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-15-2013, 04:50 AM
T77911S's Avatar
i would be more concerned that the paint could effect cooling.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
E Sully's Avatar
The only thing I would consider doing if it is not leaking is removing the bottom plate to check the shift fork, the screws can come loose. I use a very light coat of locktite 574 on the gasket.
Ed
1973.5 T
Old 03-15-2013, 06:32 AM
Brown747's Avatar
Output shaft seals are easy enough to change. You'll need the paper case gasket after pulling the aft cover off for the shift shaft seal change. Also be careful not to misplace the small rod that engages the reverse light switch. Might as well do the input shaft seal while you have it out of the car.
HTH Thor
1978 SC coupe #1834
Old 03-15-2013, 06:50 AM
Good feedback guys, I appreciate it. I will definitely check the shift fork because it seems simple enough. As far as the cooling being affected by the paint as T77911S mentioned, I wondered about it too. Now I'm no engineer, but I reasoned that with only a 200 hp car and knowing how slowly the gears actually turn in there I think the heat dissipation loss factor will be minimal. Besides I would rather stop the corrosion from getting worse, especially here in humid south Florida.
Old 03-15-2013, 06:53 AM
T77911S's Avatar
it was just a thought, you may be fine. personally, i would not paint it.
how/where is the corrosion?
RACE CAR:: sold
Old 03-15-2013, 07:22 AM
