Limited Slip
So, I had not changed the trans fluid changed in the '85 ROW (german market) 911 since I'd owned it, so I took it to the local bmw/porsch/merc shop. I believe that the tech installed OEM fluid without L/S conditioner. Now I've got a bit of gear whirring type noise.
(he also indicated that the fluid looked like it had been in there for a while...)
What would be a recommended course of action, and how quickly does this need to be addressed?
Thanks...
Old 03-20-2013, 11:09 AM
Hopefully, they used Swepco #201 gear oil and NOT a synthetic in that 915 transmission. I would also confirm they filled it completely, to spec.
Do NOT delay here; immediate resolution is needed to prevent any damage.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-20-2013, 11:28 AM
BE911SC's Avatar
The first servicing I did immediately after I bought my LSD-equipped '84 was to drain the fluid and put in Kendall 80/90 with LSD additive per Pete Zimmerman's recommendation. Shifts better and is quiet.
'84 Carrera Cabriolet
Old 03-20-2013, 11:37 AM
Thank you.
I just spoke to them, and it was a Bilstein synthetic product that they tell me is the factory reccomended fluid. It did not have the L/S conditioner.
They are willing to replace it asap - they just need to source the correct fluid.
I understand that there is an ongoing discussion on the Kendall -vs- Swepco 201 Multi-Purpose Gear Lube; at this stage of the game, should I go with whichever is available?
Old 03-20-2013, 11:40 AM
Local Mad Scientist
Andy911sc's Avatar
I would go with the Peter Zimmerman recommendation, plus you have BE911SC's review of it. That would probably save you days from people back and forth spinning your head around.
1982 Porsche 911sc
2009 Jeep Grand Cherokee Laredo X
CPA-PCA Member Since 2012
Old 03-20-2013, 12:05 PM
gearhead
Yes. I manufacture gears for a living and find this anti-Swepco movement ridiculous. Both the gear oils mentioned are excellent products that will work well in your 915 gearbox.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 03-20-2013, 12:24 PM
Can someone explain to this newbe why no synthetic should be run in my 915 gearbox?
It seems that if its the correct weight lube, with the correct characteristics and L/S additive, it should be ok; but what am I missing?
Thanks...
Old 03-21-2013, 04:29 PM
HarryD's Avatar
Thanks...
I has to do with the synchronizers. The 915 box uses a Porsche design synchronizer that is different than the Borg Warner style used in most other boxes. It needs a bit of friction to operate properly. Synthetic gear lubes are too "slippery" for the synchronizers to work properly.
If you want to learn more about the 915 transmission, look for posts by Grady Clay on the subject. Several years ago he did some excellent commentary.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-23-2013, 11:24 PM
Side note: is the L/S additive necessary for G50 LSD-equipped cars? I know the G50 uses something synthetic...
1987 Targa Indian Red
2001 Volks Jetta (winter beater)
Old 03-24-2013, 08:41 AM
GaryR's Avatar
Send a message via ICQ to GaryR
I can attest to the Kendall 80/90 LSD product (no additive needed) in use under race conditions, transmission has held up at least as well as when I was a Swepco guy, if not better.
Gary R.
Old 03-24-2013, 09:03 AM
Bill Verburg's Avatar
Use the stuff on the left in g50s the stuff on the right in 915s, no additives in either
Bill Verburg
Old 03-24-2013, 09:06 AM
gearhead
An LSD additive is not necessary for any gearbox. LSD additives make the LSD slip more. It is designed to make them run more quietly and with less chatter. Using one or not is a personal choice.
I tell my motorsports customers not to use an additive if they want their LSD to have the most bite. My products run fairly quiet and smooth because of our unique clutch design. So even in a street rod, at least with our LSD it is not required.
Old 03-24-2013, 09:07 AM
Great, thank you gentlemen.
Old 03-24-2013, 10:22 AM
