Seth Hamilton
69 911- Which Engine to swap in?
Gurus,
Looking for some advice on which engine to swap into my 69 911t hotrod. The car has some suspension work, 911s brakes, roll bar, etc etc. What isn't done yet can be done to match the engine, and I have a realistic budget for all items. I am hoping to end up with a very visceral street 911 used primarily for canyon carving and wetting my pants on the way to work. I have a slightly modified 930, an 18 GT3 manual, and a few other fast cars, so it doesn't have to be a huge power 911, but just light and fun. I am thinking something in the range of 250hp. I had an RS America with suspension work, Wong chip, full exhaust, and I loved the torque of the car. I thought about stripping the RSA down for weight reduction, but decided starting with an earlier lighter chassis would be wiser. So... how do I get some of that low end grunt in an engine that still have the right vintage feel, and very importantly the sound. The 2.2L with megaphones that is in the car now sounds wicked... but it lacks a good 80hp and tq. My current thought is a short stroke 3.2 or a 3.4 with a new set of PMOs and engine mods to match should do the trick. I don't really want to spend more than $25k on a motor itself, so likely going with a wildly built 3.6 is out. Finding something already finished is ideal. Thanks for the help! Seth
Collector of stuff most don't care about. Garage- 2018 GT3 (6spd,LWB, Chalk). 69 911t Hot Rod. 964 Turbo. 79 930. 88 M3. 72 280 SEL. F80 M3 (Modded). Boring daily driven things. Other 911s sadly sold. |
gearhead
Budget $10-15k for your gearbox if you go anything over 3l.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Budget $30-35K for properly done 3.4 that will both make you smile & be reliable.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Seth Hamilton
Thanks for the reply Matt. Why 10-15k? What about picking up a refreshed early 915? They come up all the time for under $5k.
Seth Hamilton
Are you suggesting the 3.4 would be the route you would go, or just commenting on the cost?
I would rather be driving
Lightweight would be key in the 69. I would build a mag case 2.8. Will hit your HP targets easily with the right cam. Also, won't have so much torque that you will twist your 901 to bits. Could easily run on a set of webers and would be electrically identical do your current engine.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Seth Hamilton
Likely sound advice, but deep down I am looking for a motor that would end up twisting up my 901. Also, how much of the mag case long term reliability is true? I would hate to be $XX,XXX into an engine that wont have good value down the road or for the next user.
gearhead
Not one I would trust. And it’s not just bolt in and go. You need a lot more Parts than just a gearbox to install it.
I'm actually satisfied with mine as it's set up. Of course it might not be enough of a beast for you, but it's a really nicely balanced car. '77, 2.7L w/ Weber 40s, E cams, with a bunch of dry film lube and thermal barrier coated parts, ARP rod bolts, etc., etc., '74 915, monoballs, Elephant bushings, S brakes, etc. Doesn't have the AC, and a bunch of other weighty stuff it came with originally (although I have all of it if I ever sell it & somebody wants to put it all back on). I think a similarly set up 3L would be a good choice, because the 2.7L engines are disproportionately expensive to build now, which wasn't exactly the case when I did mine, plus I already had the engine. Like I said in another thread, they must have built a million '69s. It seems like every other person on here has one.
Marv Evans '69 911E |
Seth Hamilton
I enjoy hearing all of this feedback as everyone has a differing opinion on what the right setup is. I am biased as I like huge power cars (have had some ridiculous ones). I guess I should also fess up and say I am 33 years old so perhaps I still think like I did at 16- that everything must be insanely modified and fast, even if that means sacrificing a bit of balance.
Build up an aluminum 3.0 block w/ S cams, ~9.5 cr pistons rods & oiling to allow low 7K revs, top w/ EFI & ITBs w/ a resonance manifold, back it up w/ a 915 w/ 3.1818 2.0000 1.3810 1.0800 0.8889 gears & lsd
It's be real nice to have rear SC flare to get a little more tire in there
gearhead
Seth, mag case engines are dead nuts reliable when rebuilt properly. If Ollie’s preps the case you’re golden. It was heat and emissions that killed them. Don’t forget that the 73 RS was a mag 2.7.
A 2.7 or 2.8 would meet the style best imho.
Though a 3.0 to 3.2 tuneup will be more reliable maybe (?)
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Home of the Whopper
Stroke the 2.2 to 2.4 and add some E ish cams.
Light engine in a lightweight car with plenty enough power to get you into trouble. That is what i would do, but my other car is a bug not a 930.
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S |
Seth Hamilton
Seth Hamilton
gearhead
Not much. The weight savings gets done in the chassis. For me it’s just more period correct.
3.0 liter SC with 270 Hp........
This is a 3.0 liter SC engine I built for a friend.
![]() ![]() The first several mins. of the video is not impressive but wait a few more minutes and you will see how the engine performed in the track passing everyone on sight. BTW, I did the rebuild for FREE because I only wanted to get the experience of building a race motor. Just watching this video put a grin on my face. Glad I accepted the challenge to build this one in spite of the limited experience in engine rebuilding. https://www.youtube.com/watch?v=LGSdRdyNVgc Tony |
Seth Hamilton
Bill is the one who knows his stuff, so I'd listen to him. I'd go for a 3.0L or 3.2L for potentially more power and longevity, although I built my 2.7L with longevity in mind. If you're 33, I have 43 years on you and longevity is of interest to me. I think you should remember you can hot rod it to the hilt but probably never make it beasty enough to compare with your other (or some of your other) cars as you described. So it's going to be a car to drive for its raw appeal. Of course you could always go the modern V8 or V6 route for power, but it would still handle like a fifty year old car. So if "everything must be insanely modified and fast", it might not ultimately be your thing. Some of the reasons I like mine is because I can get in it, it feels relatively roomy because you're not cocooned in, has simple controls and instruments rather than a lot of electronics and digital stuff, it's small and light, and I really like the shape of the longhood 911s. I just like the car and don't feel I have to prove anything when I'm driving it - maybe it's just because I'm pretty old.
