82-911sc electrical problem
Need help/direction.
PROBLEM… quick flash on turn/hazard (all bulbs are good)
…occasionally while driving dash brake light comes on and tach goes crazy for 5-10 seconds
ELECTRICAL SHORT … but where do I start and how do I chase it?
I've owned this Porsche for 30 years!!
Thx.
Old 03-28-2013, 08:28 AM
pete3799's Avatar
Turn signal flasher relay is the likely cause of your rapid flash (was on mine anyway).
Get a volt meter and monitor it while you drive. I'm guessing a voltage spike is causing your Brake light/ tach problem. Time for an alt. rebuild i'd say.
Pete
79 911SC RoW
Old 03-28-2013, 09:04 AM
schumicat's Avatar
agree with Pete...sounds like voltage regulator. they cause random elec. gremlins when failing.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 03-28-2013, 09:33 AM
kodioneill's Avatar
Advanced auto sells a tool that plugs into your cigarette lighter that has a nice readout for checking battery voltage and charging conditions not very expensive either $15-20.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 03-28-2013, 09:52 AM
