915 drain/fill Plug
quick question, before i go hammering away at my cheater bar to loosen the 17mm hex, could some one tell me which direction the plug must go to loosen, i get disorientated under there and don't want to be massively tightening it
1980 911 SC Coupe 1987 944 |
Hi
If you're underneath the car, turn it to the left.
Remember: Lefty Loosey, Righty Tighty. I know, corny, but it works.
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
hi thanks, ok so does that translate into counterclockwise to loosen?
i remeber righty tighty from gradeschool, alsways wondered if that 100% true?
Schleprock
Yep its CCW. Since the threads are tapered metric pipe thread, be prepared to need a LOT of effort to loosen the plugs. Tapered threads interfere with each other to seal. How it works is, easy to tighten (over-tighten) and very NOT easy to loosen in many cases.
Kevin L '86 Carrera "Larry" |
![]() thanks!
Make sure you have the fill plug out before removing the drain plug.
The reasoning for this should be obvious..
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
yeah, i got the fill plug loosened with only minor back injuries, that drain plug doesnt want to move
If under the car from the rear, you position your wrench on the left side of the drain plug. then push left or away from you towards the drivers side of the car.....lefty loosey
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
Racer
This keeps the side of the transaxle from getting oil all over it if the oil level is a little higher than the fill plug. Scott |
great advice, thanks for all your replies
![]() as always with this sort of thing it comes down to tools....i need to get a 17mm that will go on my breaker bar then i shall conquer and rule over all tranny drain plugs
Member 911 Anonymous
Make certain the 17MM is fully seated and squared up before using the breaker bar. When you put it back, it is only 18 ft lbs torque or snug and 1/8 turn.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
AutoBahned
use Kroil; tap; wait; repeat then use a hammer on the breaker bar CCW while looking at it |
brett..go to parts heaven when you finally get that plug out. replace both plugs with the "outie" type plugs. not the allen 17mm. i think mine take a 19mm socket. way easier to contend with, should things get stuck.
i am in concord, so throw up the Bat signal if you get stuck (sorry pun)
poof! gone |
thats an excellent idea vash, im going toi switch them over much rather have a bolt than this allen thingy
thanks for the help
Senior Advisor
you can also get a 17MM allen 1/2" socket if you want and get real medieval on that plug if you want
08 Cayenne Turbo Last edited by James Brown; 04-08-2013 at 05:29 PM.. |
