how change gauges lights
I'm new doing this and I need some help to change the gauges lights
in special the speedometer because when I turn on the driving lights it turns on ok but when I turn on the headlights one of the 2 lights turns off
Old 04-15-2013, 03:11 AM
Senior Advisor
James Brown's Avatar
humm something going on there. The lamps are on the back of the gage, pull the gage out from the rubber gasket holding them in. you will see the small sockets that hold the little lamps. Search for LED lamps and you might like that change
08 Cayenne Turbo
Old 04-15-2013, 03:32 AM
It sounds like one of the lights in your speedo has been replaced by the indicator light for the parking lights. If so, it will turn on when the parking lights/dash lights are on but will go out when the light switch is pulled all the way out for the head lights. Take a close look at your gauges. Turn on the parking lights and see if the green light comes on (I forgot which gauge holds the parking light--speedo or tach) and also if it goes off when you pull the switch all the way out. If it never comes on or if it fails to go out, then the light has likely been switched with the one in your speedo. Pull the gauge and switch them out.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 04-15-2013, 07:33 AM
pete3799's Avatar
To get the lights out you want to pry up on the metal lip not the plastic.
Pete
79 911SC RoW
Old 04-15-2013, 08:03 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Yeah, it looks like someone before you had mixed up the lights. Remove gauge and check the bulbs are in the correct inserts.
PMed you.
'85 Carrera Targa
PCA/POC
Old 04-15-2013, 09:52 AM
