Running hot
I have an 85 911 cab that has been running hot recently. The temp needle has steadily increases during startup as normal. Once I reach normal running temp the needle starts bouncing up and down in about 1mm increments. This continues as I drive and at a stop light and continues to register hotter and hotter. I have not let the needle pass the second tick on the temp gauge for fear that I'm running too hot. I'm getting good oil pressure and when I check the oil level it's halfway between high and low marks on the dip stick. All this happened pretty quickly in 80F weather in about 15 mins of city driving. Could this be a bad temp sender unit or bad engine thermostat ?
Are your oil cooler pipes hot that are at the fender mounted oil cooler?
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
near the crankshaft pulley. Also the gauge connections Red/Black wires. Let us know what you find. pm me as needed. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 08-16-2013 at 04:40 PM.. |
Sensors.
Here you go........... ![]() Check/clean connections. pm me as needed. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Member 911 Anonymous
Dr Gerry, knows :-)
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Oil pressure sensor.
Thanks Gerry, I was able to source one locally already for the same price. I will post an update after installation this evening. |
They should be HOT as in burn you if the engine is 200 degrees, those oil pipes should be 200 degrees. If they are just warm, something is wrong.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
