LinkBack | Thread Tools |
Rating:
....control Last edited by wwest; 04-22-2013 at 07:35 PM.. |
...maybe a window airconditioner and a very long extension cord would do the trick.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender Last edited by fintstone; 04-22-2013 at 07:23 PM.. |
The statement makes perfect sense. We are discussing potential sytems for pre '90 911s, not 2014 Lexus. They are somewhat different.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
PM me your address, and I'll send you temp prove to stick in your vent. It seems you're either too poor to afford one, too scared to share the results, or maybe you don't even own a 911. If you can afford a prob, you have the knowledge to use it, and you own a 911 - then being a troll is the only other reason you wouldn't post this info.
88 Carrera - Venetian Blue 2002 Audi S4 Avant (KIA) |
If you don't understand then simply say so. A good measure of an A/C system's cooling capacity relates to how different, how COLD, the outflow air will be vs the inlet air temperature at a specific airflow volume. How cold will that room temperature, 72F, gallon of milk get for each minute left to chill in a 'frig...? |
You and I both diverged from the current subject, pre '90 911s, to post 1990 products. "..They are somewhat different.." Yes, different in the manner I stated, to which you jumped in and disagreed, falsely. |
Banned
Okay..? |
blah-blah-blah,..no data testing points. Until that;s provided , you are dead in the water, WWEST. And I do mean truly dead. Quite tiresome with no test data.
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Gentlemen, show of hands? Last edited by kuehl; 06-01-2013 at 07:42 PM.. |
Explain why that is not the same as vent (outlet) temperature at a specific ambient temp (input) since the ductwork (air path) and evaporator fan are fixed (volume)? If you don't understand, them simply say so.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender Last edited by fintstone; 04-22-2013 at 09:01 PM.. |
Evaporator fan are fixed (volume)...not in any of my 911s, |
The amount of cooling a given volume of air receives, temperature delta, upon each pass through the evaporator is a reliable measure of he system's cooling capacity. |
Banned
The max volume of air is fixed on all my 911s. It is on yours as well.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender Last edited by fintstone; 04-22-2013 at 09:20 PM.. |
Banned
This doofus kills every damn AC thread there is by trying to shout down anyone who actually knows anything about these systems. |
Banned
When he specifically posts that he has tested his add-on fans and they will duplicate the performance posted above (which is what I would expect from an A/C system): "In 95F ambient air temp with full sun (over 300 shortwave insolation) system produces copious amounts of 40F air at high blower setting and a steady flow of 32F air at medium blower setting."...then he will be interesting. Until then...he is just tilting at windmills (and folks with well-designed, proved products). No one is looking for half a solution.
