Banned
What I find hilariously ironic is that after bashing the living schitt out of you, he then uses your website as "proof". Selective use of data, while ignoring other data that doesn't agree, is called "lying" in most scientific circles. |
Banned
See, if the numbers proved him wrong, he wouldn't be able to defecate all over Griff at EVERY opportunity - you'll notice that he takes any and every opportunity to call Griff and his products names in all of these threads. I don't know what Charlie did to this guy's dog/family, but it must have been REALLY BAD.
Comparison: 2001 C4, 2001 AWD RX300, and '95 LS400. When driving either of these vehicles the temperature setting I use is 72F. These modern A/C designs lean more to the side of avoiding discomfort from too COOL/COLD outlet airflow in fully automatic mode. So, to get QUICK initial cooldown I often must turn the system to recirculate (post a period of FRESH long enough to purge the HOT cabin atmosphere) and maximum COOLING until the cabin atmosphere, and somewhat less so, the cabin materials/surfaces, are cooled down to a more satisfactory comfortrange. The C4 has a manual switch modification that I use to open the compressor clutch circuit when I have no need for A/C cooling capability. Otherwise it, like the Lexus', would operate 24/7 even in the dead of winter. Conversely with the LS I often manually close the valve that allows engine coolant to enter the heater core during the summer months. The RX came with a factory capability of disabling the A/C compressor 24/7 operation indefinitely to avoid the cooling aspect except when needed. The '88 Carrera: I rarely need to go to extremes for rapid cabin cooldown but when I do it means lowering the windows slightly and turning on the fresh air blower to most quickly purge the cabin of HOT atmosphere. Other than that rarity, like the Lexus' and C4, the system gets turned to maximum cooling and blower speed until the cabin is cooled down to a satisfactory comfort level. Once that point is reached the blower gets reduced to "nil", lowest setting, and the Compressor cycling point "tweaked" to satisfy our cooling needs while also avoiding the discomfort of excessive cool airflow toward our face and upper body. So, the '88 Carrera, for us, offers A/C cooling capability equal to either the Lexus (Lexii..?) or C4. So I have had no reason to measure system vent temperatures and still do not see the reasonableness of such a request given the completely satifactory system performance we have experienced and now related. But if it pleases you, still... A few points. The '88, '95, and C4 all have aftermarket window tinting. The RX came with factory tinted windows. The main reason I added the fans to the '88 resulted from it's often use in the high desert areas of WA and OR. Absent that need I think we were satisfied with the factory system. Last edited by wwest; 04-22-2013 at 09:51 AM.. |
I tend to stay away from the A/C threads due to the drama (I get enough of that at home with my 13 yr old daughter!).
FWIW, I went with the full monty kit from Retroaire. I went with them mainly because they had the PFC rear consenser as part of their package. My stock tube and fin had developed a leak from rubbing on the coil. I did the entire conversion and charging myself and couldn't be more please. Cold air at a higher velocity even on the hottest AZ days! The Sanden compressor upgrade over the York vibrates less and draws much less power. It also weighs less and helps unclutter the engine bay. Worth the cost and effort. The only thing I would do different is to replace the front tube and fin condenser with a PFC condenser. The fins on the stock T&F condenser are brittle and flaking off due to being old and thermal cycles.
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
Loved the duel Kuehl w/R134 on my '74 Targa and will likely upgrade my '89 eventually. With the '89 R12 version operating perfectly, vent temps are about 15 degrees lower in the duel Kuehl system with no front condenser or fan (except on the Kuehl rear fender well condensers). The well maintained, factory improved version in the '89 is better than nothing, but never truly comfortable in the summer except at night. Personally, I can't see driving an uncomfortable car...even a KIA. I want vent temps in the mid to low 30s at 90 degrees ambient. I don't find it too difficult to spend a grand or two on AC when glass-out paint jobs and engine rebuilds are often $10k.
Banned
Hmmm, I've never filtered anyone in my whole time on USENET and the various car forums after that, but I might have to explore vB's user tools... |
Always Be Fixing Cars
Original Poster here
Wow. In my many years of posting on car forums I've never seen anything like this. Thanks to those offering solutions. Kuehl: Many reviews and PMs suggest your all-in system can turn the 911 into a meat locker in New Orleans. My question is: for someone who wants not to sweat in their car in New England (95 deg, high humidity for lets say 3 mos) but is happy with a system that is not Lexus grade, what would be you recommendation for a "phase 1" upgrade? I'd like to do things that don't preclude further upgrades but allow me to test the system to see if its right before investing say $3500. I'd be happy to start with an investment closer to say, $1000 and see where it gets me. Is this a reasonable position? Quote:
'91 964 C4 - New Daily '73 Alfa GTV - 90% done 50% to go '65 912 - Welding in process |
Quite a clear indication that converting "our" systems to R-134a without the addition of a binary control switch (or other measures) to limit high pressures due to compressor "over-run" thereby possibly developing a unique version of the Vent-to-Atmosphere high pressure relief valve. "Other measures"...Use the activation of auxillary refrigerant condensing BOOST. For instance use a trinary pressure switch, 3rd function, to switch on an extra cooling fan(s) to prevent an extraordinary rise in system pressures, engine running or no. Now that we know, must acknowledge, that excessive high side pressures can and do exist, might it be possible to admit that might be the base case of refrigerant leakage, system pressures BEYOND the design specification for those infamous "non-barrier" hoses used so successfully elsewhere within the automotive industry. Last edited by wwest; 04-22-2013 at 10:24 AM.. |
Cheapest A/C upgrade is to get a 964 or 993.
Next best is the Griffith system I have a 911 Targa in San Antonio running R12. It is an original VWoA unit with a Sanden compressor , rear engine condenser. Plus , since I have the front RS spoiler I placed the normal front condensor in place of the normal center oil cooler. Once I'm moving I've got plenty of A/C. My problem is that with all that glass, when I leave it parked it takes some time to cool down, short runs are the worst. Stopped in traffic is just marginal.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Banned
Barrier hoses. Front condenser. Drier. Serpentine evaporator. Evaporator blower/controls upgrade. Convert to R-134a. Where I live, it can get very hot - over 100 degrees F. But it is rarely humid. In fact, during really hot times, it can be 10% humidity or less. I can get a delta of 30 degrees between the interior of the car and the outside air, easily - and maintain it. I don't try for much more than that, because when it's 100 out, 70 inside the car is very nice. I might try and see what kind of total delta I can get this summer - let's see if I can get the interior down to 50 degrees, LOL. |
Dude. Please. This isn't high school debate club. Just looking for info. Not swallowing in all, just reading. Shhh.
For any AC setup to work consistently (and that is what we all want), you need to switch to 134 and get barrier hoses. The old hoses just leak a lot, for various reasons, and as a foundational AC setup, you need to get barrier hoses. You can have them made locally somewhere, or buy them from various vendors. Because you'll be opening up the system, you'll need a new dryer. At that point, you'll might want to think about a new compressor and an additional condenser. Zimms, Kuehl, Griff - any one will do the trick. I think that's a solid start. If funds are a constraint (and who doesn't care about how much they spend?), I'd research Griff and kuehl, and maybe start with an incremental setup from each. But, what you don't want to do is buy a bunch of parts without thought to how they work together. So, buying a compressor from someone, then a condenser from someone else - they might not be the most efficient setup, though it may be the cheapest. Both Kuehl and Griff are awesome - from all standpoints. But, as a minimum, you'll need 134 and barrier hoses. Check to make sure the fan on the front condenser works, too. It's really hard for anyone to evaluate what your needs are, but I'd start with that. It may provide the cooling you need at HWY speeds, but it's not going to be enough for stop and go traffic on a hot and sunny day. For me, the AC setup needs to be damn good as nothing is worse than sitting in stop and go traffic with sweat dripping down your back. The system either needs to work well at all times, or not at all. That's just my personal viewpoint. Which compressor do you have, and do you have the condenser on the rear deckled? Also, what year was your car again? If you can do the work yourself, than a grand in parts will get you pretty close to what you want, I'd think. That's what all my parts ended up costing. It was the 1700 in labor that was expensive.
88 Carrera - Venetian Blue 2002 Audi S4 Avant (KIA) |
Shall I assume that's the best you can do even at consistent freeway speeds, elevated engine RPM? Last edited by wwest; 04-22-2013 at 10:45 AM.. |
Nobody should entertain this guy anymore with posts. He can either figure out how to contribute in a valuable way, or we'll just ignore him.
Interior temps are variable based on tinting, insulation, etc. Vent temps are what one should compare.
Banned
Then that person's posts won't show. You can see that the person posted, just not what they posted, unless you click on the link "view post". wwest will continue to p!ss in Griff's Wheaties, no doubt. I just won't have to watch it. |
Banned
I know that the interior of the car can go from being damn hot to almost comfortable before I reach the first stoplight, so the system functions pretty well already. It doesn't take me long to turn the thing to the lowest setting, and run it that way for the rest of my trip. |
