water in rear footwells
Has anyone heard of rainwater entering the cabin from below? After driving in heavy rain I've noticed that I have quite a bit of water in the rear footwells. I don't think it's coming from above (e.g. sunroof) or from the doors or windows because all is dry everywhere except the floor. It's as if water is coming up through the floor. My car is an '88 carrera coupe.
TIA,
Hugh
Old 04-19-2013, 08:18 AM
Most likely a leaking rear window seal, BTDT.
Bernie P
Old 04-19-2013, 08:43 AM
Evil Genius
Rusty Heap's Avatar
Most likely the rear window seal, and most likely the horsehair backing of your rear seat bottom and rear firewall is soaked too. I'd be pulling those out to triple check as you've only found the water that you've seen.
An auto glass place was able to get silicone under the lower edge corners to keep my window in place. The electric rear defog wires run along the side of the gasket and they're a beatch to replace.
Life is a big ocean to swim in.
Wag more, bark less.
Old 04-19-2013, 08:54 AM
Thanks, guys. Not really good news: replacing the window seal (I assume removing the window itself) sounds like a nasty project.
I don't feel any wetness around the window, but I guess water follows seeps around in strange ways.
Hugh
Old 04-19-2013, 05:09 PM
Have you checked to see if your rear sunroof drains are clean and clear? I had a similar problem that drove me nuts! Open your sunroof and pour some water in the "channel" on either side of the sunroof and make sure it flows out of the rear drain holes. (open rear lid and look at upper left and right for little holes).
Here is a link to my similar problem and the solution.
Eureka!!! Found rear seat water leak Sunroof related!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 04-19-2013, 05:58 PM
uwanna: thanks for the great link.
Sounds like the symptoms for a rear window and a sunroof link are similar. Need a dry day for me to check, though, and we haven't had one of those (let alone sun) for two weeks here in Chicago.
Old 04-19-2013, 08:24 PM
LakeCleElum's Avatar
Not only agree with the rear window seal, But, also:
If you don't take care of this, the water will rust out not only your floor pan, but also the come thru the Rocker on that side....For now, drill a small hole to let the water drain...
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 04-19-2013, 11:27 PM
wayner's Avatar
Agreed. And the parcel tray and the rear seat buckets will also disintegrate under that damp carpeting.
Here is a picture of how the leak starts. (I just installed the rear window using a new but old in a box window seal that was no longer as flexible as when it was purchased).
As a result, it didn't seal and I had to reinstall using a brand new fresh seal.
Here is a picture from my leak test.
The water takes the path of least resistance to the floor and eventually makes its own path out of the car as stated above.
SOLD - 914 wide body hot rod
Old 04-20-2013, 06:33 AM
OK, I removed the two folding seats and determined that the carpet underneath is also wet.
The seat back isn't really, but I'm sure there is a water path somewhere.
I undid the zipper on the headliner and the piece that covers the sunroof mechanism. I haven't done the drain test, but I didn't notice any dampness there, so I'm leaning towards the rear window hypothesis.
A couple of questions: to fix the window I assume you have to remove the seat backs and the "shelf" where the speakers are. How do you remove this: do you need to dismantle the material on the sides, rear armrests, etc.? I've removed all the screws I can see: is it now just a matter of tearing stuff off?
And the rear window: does it need to be removed, or can it be caulked in place?
Thanks!
Old 04-21-2013, 06:16 AM
AutoBahned
RWebb's Avatar
yes, tear it all out down to bare metal; replace with newer, better materials once you find & fix the leak
seat backs have big screws at the hinge point; seat bottoms are just glued in
sometimes rear windows can have stuff injected by a glass shop BUT you may have rust on the frame
how good are you at welding?
Old 04-21-2013, 11:39 AM
Thanks!
If you have a sunroof draining problem, the water will drip down thru the perforations in the headliner> ERGO the seat bottoms will be wet but the back panel won't be.
Get out a hose and flood water over top and closed sunroof and look for drips thru the headliner, and also make sure water flows down thru the drains.
That's how I found my leaks.
Old 04-21-2013, 11:49 AM
wayner's Avatar
You can get an idea of minor damage on page 10 of my thread.
Saving a 73 from the crusher...
or worse, on Chris car midway down this page
My '73 Hot Rod is Home!
I hope you caught it early. Also, time to check the front window. I have seen cars with no metal left under the dash pad above the gauges because of an undetected water leak.
Old 04-21-2013, 05:43 PM
Member 911 Anonymous
DRACO A5OG's Avatar
to elimnated the floor pan, in the garage at night place a shop light underneath, check the cab, if yiu see pin holes of light, there is your culprit, use 3m weather strip adhesive and plug them up, if no light, default to seals.
'85 Carrera Targa
PCA/POC
Old 04-21-2013, 06:30 PM
It's the rear window. I'll get it done professionally. Any suggestions?
I'm hoping I won't have a rust situation since the car is galvanized (and '88). Still, that insulation material holds in a lot of water. I removed the piece on the parcel shelf, but not the piece that covers the rear seat.
Old 04-21-2013, 08:18 PM
AutoBahned
RWebb's Avatar
strip all the foam out - you may also have mold...
Old 04-21-2013, 08:42 PM
wayner's Avatar
I would count on some even minor cleanup of the window tracks while the glass is out.
If it were me, even if not technically inclined, I would remover the rear glass myself, do the cleanup, and then if you don't feel up to it, have a mobile installer come over and install the new one.
To remove, the glass, take a long razorblade knife and cut the seal flush with the glass (under the trim)
That way once cut, you can remove the trim without having to pry it off.
Old 04-22-2013, 05:31 AM
