Bad spark cap connection
I seam to have bad connection between spark plugs and the cap (wire housing)
Is there a quick fix to this problem or do i need to get new wires?
Glenn
911S 1976
Old 04-22-2013, 06:08 AM
Drisump's Avatar
All of them? If all of them are having problems, the issue is likely upstream. In my opinion it would likely be the main lead from the coil, the coil itself or the power to the coil. To me it is unlikely that the wires are the sole problem. If the wires are obviously old, they should be changed anyhow.
Old 04-22-2013, 06:34 AM
schumicat's Avatar
look at the plug ends, the metal part is often split and you can squeeze it slightly with pliers to make the circumfrence smaller so they grip the plug better.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 04-22-2013, 07:47 AM
76 911S Targa
You might explain the problem a little more. If you are referring to the wires not sliding into the cap far enough to make good electrical contact, I had a similar problem with new ignition wires. The rubber boots were so new and springy that the wires would slide off the smooth plastic of the distributor cap. I simply pulled the wires through the rubber boots a little farther and pushed them into the cap firmly and all was well.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 04-22-2013, 08:19 AM
Not sure which ones it is, but I know for sure that it is plug related. When the engine starts to hold back, I stop the car and press the caps firmly down on the plugs. After this the engine runs smoothly again.
Old 04-22-2013, 11:48 PM
Can i spray WD40 into the distributor cap?
Old 04-23-2013, 03:46 AM
Senior Advisor
James Brown's Avatar
best to spray into the boot of each wire, old trick but seems to work, clean up any overspray from the cap area
08 Cayenne Turbo
Old 04-23-2013, 09:56 AM
