Reiver
I hardly look at the speedo...get a calculator for rpm speed that uses your gearing and tire size...I just use the tach.
Mines about 6 mph off and everyone with an SC that I know says about the same. |
I had mine rebuilt, the gear broke inside. They also 'calibrated' it.
I replaced the funky reed switch in the tranny at the same time. It works but it's off by about 5 mph. Who knows why. If you drive with the traffic your odds of getting a ticket are low. If you get something like a 9500ix and radar is in the area, it will show you your speed. The 9500ix is an expensive investment but with its built in memory, update capabilities, accessory"live" mapping on your droid or iphone... we'll its a pisser! Can't beat it and less false alarms than the Valentine. One of the best investments I've made besides wide band AFR display. |
Undocumented User
an optimistic speedo is the cheapest way to get performance out of the car.
When I fixed my odometer gear, I used a gps to calibrate the needle, making small adjustments until they agreed.
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
Not sure what your question is.
El Duderino
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Air Medal or two
Mine reads way fast and gets near accurate at high speed.........Like someone said...they are all off........maybe just live with it......
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
El Duderino
A 15-in tire has a theoretical circumference of 47.1 inches. A 16-in tire has a theoretical circumference of 50.24 inches. If the speedo is calibrated to a certain number of revolutions, then: 800 revolutions 15 in: 47.1 * 800 = 37,680 in (total distance traveled) 16 in: 50.24 * 800 = 40,192 in delta = 2512 in (6.7%) 1200 revolutions 15 in: 47.1 * 1200 = 56,520 in (total distance traveled) 16 in: 50.24 * 1200 = 60,288 in delta = 3768 in (6.7%) 1600 revolutions 15 in: 47.1 * 1600 = 75,360 in (total distance traveled) 16 in: 50.24 * 1600 = 80,384 in delta = 5024 in (6.7%)
El Duderino
Oh and a 6.7% calibration difference at 20mph would register a difference of about 1.34mph and at 60mph would be a difference of about 4mph. I think this is consistent with what most people see as the difference between real and actual.
Recreational User
Recreational User
From all my experience and what I've seen reported on this board for the last 9 years, the typical difference is twice what you suggested.
My SC is off by almost 9%. At 80MPH indicated my GPS will read 73MPH. Must by a German thing. I also have a BMW R1200RT and an R60/6. Both of those speedos are also optimistic.
Lorraine 83 SC CAB RoW 2003 C4S coupe 07 BMW R1200RT 76 BMW R90S 76 BMW R60/6 |
I believe the German government has VERY BIG FINES on a manufacturer if any of his cars are found to UNDER report speed. Thus they design the stock speedo to OVER report speed by 5% or so. Not sure when this practice started.
1986 930, Garnet Red Metallic Previous P's: 65 911, 66 911S 63 904 (086), 63 904 (038) 70 914-6 |
El Duderino
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. Last edited by tirwin; 04-23-2013 at 08:22 AM.. |
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
El Duderino
Thinking out loud here, but what happens if someone changes the gear ratios in the transmission. Does the final gear ratio change at all?
Fb = M/S
I thought about the wheel size as well. Although my 81SC came from the factory with 16-inch wheels, the PO or dealer changed my speedo - I think my car came with the idiotic 85 MPH speedo. What I have often thought about was when the speedo was replaced, were there two speedos available? A 15-inch version and a 16-inch version, each calibrated for the appropriate wheel size? It just seems like my speedo is calibrated to 15-inch wheels, not the 16's I have.
I wonder how NHS "calibrate" their speedos? Is it done on a bench? If it is, how do they know if they are calibrating for a 15-inch wheel or a 16-inch wheel, because when they "calibrated" mine, they did not ask, although they had my car at their shop. I simply assumed they used the dyno rollers because I saw them there. That is why I was quite surprised that after my speedo was calibrated, it still registered higher speeds than I know I am going. And for me, I just didn't like the fact that my mileage is probably higher as a result of the incorrect speeds. |
El Duderino
I looked for it a little while ago and couldn't find it. I think it was a guy sitting at his kitchen table with a cordless drill and a car battery. He had the drill hooked up to the speedo cable somehow and I can't remember what he used to measure the RPMs.
According to one source I found says the US requires something like no more than 1.5% variation. About 5% seems pretty common so it is kinda interesting that so many people are seeing greater variation than that. Not too much you can do about it though. Send it off to a shop that knows what they're doing or live with it. If I ever send off my gauges I would have it done, until then I'll live with it. I keep the Escort app running on my smartphone when it counts the most anyway.
