Seriously? Air flow (fan speed) has everything to do with freeze up. Think about it.
On the other hand yes, provided the control system is faulty to the point of allowing evaporator freeze-up, but has "limited" refrigeration capacity, with a high(er) volume of airflow, airflow consistently ABOVE 32F, no freeze up will result. But keep in mind that like your fridge's freezer section, your A/C is a closed system and will FREEZE unless you open the "freezer" door often enough. Last edited by wwest; 04-25-2013 at 08:33 AM.. |
where do you come up with this stuff?
what if the water is already 33 degees? go pull the fuse to the indoor unit of you home AC and watch how fast the evap will freeze up. why do you think one of the first things to check on a home AC unit is the air filter. a dirty air fitler reduces air flow and WILL cause the evap to freeze.
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
I have 2 of those ~12,000 BTU portable air conditioner/heat pump (exhaust/intake air hoses through the window) units for heating the 2 garages on the property, and they both have active freeze up prevention controls. |
And amazing so many older home HVAC units don't utilize an evap freeze out switch. So inexpensive to adapt. Most 'in the window' or 'in the wall' don't have them either, I've seen many units just turn to a block of ice, brand new, right out of the box. So, we are fortunate the 911/930 have a simple and effective 'thermostat-freeze out' combo control that if properly located in the evaporator coil... works! Last edited by kuehl; 04-26-2013 at 03:16 AM.. |
Simplistic, now there is a word German engineers would like. Last edited by wwest; 04-26-2013 at 05:43 AM.. |
Thread Tools | |
Rate This Thread | |
