mystery wire?
Been having a idle issue with my 81 911sc. Idle fluxuates randomly between 1100and 1600rpm. Was looking around for a vacuum leak and found this ground lug at the back of the engine that was disconnected and appeared to be making intermittent contact with the engine block. When I ground the lug, the engine idle drops from 1600 to 1100rpm and is stable. What is this ground connected to? (see pic below)
Thanks, Mark ![]() ![]()
MAD4PORSCHE ![]() 81 911SC Targa |
There is a threaded ground post/stud on the left bulkhead near (behind) the fuel filter and accumulator, you have to "feel" for it or use a mirror. Will the ground (brown wire) harness reach that?
Keep the Shiny Side UP! Pete Z. |
Senior Advisor
looks like a ground wire harness, any strange or non working stuff on the car? might be the problem with the idle
08 Cayenne Turbo |
It's definitely the cause of the idle and I did find a lug on the engine to connect it. I was wondering what module the ground is for(maybe the computer?) I comes from the bulkhead connector right behind it to the right of the shock tower.
Senior Advisor
if you cant find it, on the forward of the left inner fender, by the fuel filter, you can try a bolt on the engine itself for now.
08 Cayenne Turbo |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Bolt.
10mm
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Senior Advisor
good eye
08 Cayenne Turbo |
Looks like the ground for the engine sensors. Mine is connected to the alternator.
Jon |
