Hellraiser's Avatar
Send a message via MSN to Hellraiser
Firewall question
What would you do when you uncovered this PO's Artwork:
A) keep the holes, enlarge them and use them as inspection hatches
B) replace the entire firewall with an original one
C) remove the entire firewall and replace it with removable aluminum sheet metal
D) ?
The car will be used for trackdays and as a "weekend warrior"
Thanks!
Old 04-28-2013, 10:55 AM
RETIRED
Joe Bob's Avatar
Assuming that you are dropping the engine?
I would weld in patches of similar gauge metal. Grind to clean it up, POR-15 anti rust coating or equivalent.
2012 ML350 3.0 Turbo Diesel
Old 04-28-2013, 11:38 AM
Hellraiser's Avatar
That's an option, but maybe I could benefit from the fact that it's
already messed up.
How much do the people that have removable firewalls actually
use them?
Old 04-28-2013, 01:12 PM
Reiver
Reiver's Avatar
Clean it up nicely and post it on the 'lightening my 911' thread...you may be in new territory
Old 04-28-2013, 02:09 PM
Hellraiser's Avatar
Ok, I've decided to cut away everything inside the red line
and replace it with aluminum sheet metal.
Old 04-29-2013, 12:07 AM
Uncertifiable!!!
Uwon's Avatar
Personally I would weld in steel sheet to maintain structural integrity of the unibody, my 2 cents worth. It will look better too.....
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 04-29-2013, 07:28 PM
Does the firewall not provide something in the way of rigidity? I'm not sure I'd remove anymore metal but those openings sure could come in handy. Have you considered making inspection doors at those locations and just cleaning up the PO's raggy edges?
Old 04-29-2013, 08:22 PM
irl irl is offline
irl's Avatar
Send a message via AIM to irl
Just weld in the three circles and dont cut it more. No reason not to do this. Every beginner welder cuts out too much at first and then gets a lot smarter
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 04-29-2013, 08:25 PM
ROW '78 911 Targa
timmy2's Avatar
Well, I guess that's one way to get to the shock towers...
Weld it up with sheet metal.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-29-2013, 09:58 PM
Synchro Joe's Avatar
+ 1 Weld it up with sheet metal.
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you.
Old 04-29-2013, 10:39 PM
Hellraiser's Avatar
Finally found the time to remove the engine and weld it with sheetmetal.
Old 07-28-2013, 03:21 AM
