carl74344's Avatar
ROW vs. US CIS
I have a 1982 911sc. i was thinking if the ROW 911 has a simpler CIS system why can i not change to the ROW system? what would be the good and bad about that?..............thanks carl.........................
1982 guards red 911 sc work in progress
Old 05-03-2013, 07:15 PM
ROW '78 911 Targa
timmy2's Avatar
I don't know if it is compatible as I believe the ROW cars continued to have larger porting than the US versions. May make adjusting it a real bear.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-03-2013, 08:05 PM
carl74344's Avatar
is the only difference the pollution? if it has less stuff it might be better to tune.
thanks carl
Old 05-03-2013, 09:55 PM
Josh D's Avatar
'80-'83 US are small intake port heads
'78-'83 RoW are large intake port heads
'78-'79 US are large intake port heads
You would have to open up the ports on your heads or switch to early US or any RoW head to use RoW CIS
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 05-03-2013, 10:17 PM
carl74344's Avatar
what would be the gain? would it be worth it? carl
Old 05-04-2013, 12:19 AM
Recreational Mechanic
Nickshu's Avatar
In 80-83 ROW cars also had higher compression pistons. One reason for the larger intake and different fuel distributors.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 05-04-2013, 04:15 AM
DanielDudley's Avatar
I had an 81 euro, and I currently own a 78 with Euro pistons and cylinders and a euro fuel distributor. They go together. I am certainly no expert, but you will get good results from converting to SSI heat exchangers and a free flow exhaust. If you ever change over the rest of the engine, you will need those anyway.
Old 05-04-2013, 04:36 AM
Josh D's Avatar
So did US cars.
'80-'83 US 9.3:1
'80 RoW 8.6:1
'81-'83 RoW 9.8:1
If you were building a 3.0 CIS motor, you'd want to mimic the 204 hp 930/10 RoW (big port heads, 9.8:1 CR, RoW CIS and ignition distributor)
Old 05-04-2013, 08:19 AM
Nickshu's Avatar
Originally Posted by Josh D View Post
So did US cars.
Still don't understand your statement...
An 82ROW has higher compression pistons than a 82US. 9.8 vs 9.3
Sent from my SPH-L710 using Tapatalk 2
Old 05-04-2013, 03:59 PM
Reiver
Reiver's Avatar
Think he meant that the earlier US SC's had a lower comp ratio than the later SC's that went to 9.3.
You could prob use the ROW CIS, I don't think it is 'simpler' it just delivers more fuel due to the comp ratio need and will make you run richer as lean and HC don't mix. Bang.
Old 05-04-2013, 04:58 PM
I am in the process of doing this right now. I started with a 82SC US. I have added 9.5cr Mahle 98mm P/C, I had the heads ported to the larger intakes with dual plugged heads, a Webbs stainless airbox, and the rest of the intake from a 79SC large port. I have taken forever to do this because of the "while you're in there" issues such as rebuilding the fuel distributor and warm up regulator(making it adjustable of course). I'm going to have the wiring harness rebuilt because A. It looks like crap B. I am planning on using an Electromotive dual plug ignition system and I need to find out which wires from the harness that I can safely eliminate. If anyone can tell me this, Iam open to suggestions. Phil
Old 05-05-2013, 05:40 AM
Josh D's Avatar
In 1980, much like 1975 and every succesive year after, the CAFE and emission standards where rising quickly in US. In order to meet those standards for MY 1980 and avoid gas gussler tax in US, Porsche raised compression ratio and increased port velocity at lower engine speeds by making the intake ports and runners smaller. There was also the change in ignition curve and the addition of the O2 sensor with a lean fuel curve. All of this was done to improve fuel economy and lower emission while maintaining performance at the lower speed limits in the US. The changes effectively created higher cylinder pressure at lower engine speeds creating a very responsive engine with a nice flat torque curve at lower engine speeds. This was a common formula for a lot of manufacturers selling cars in the US (ever heard of BMW's ETA engines?).
In Europe (and everywhere else) the standards were different as well has speed limits in some areas so they had more free reign to build and tune to those conditions.
Even with lower compression than the US version, the '80 RoW engine with bigger ports, advanced cam timing, richer fuel curve, and more ignition timing still generates more torque than the '80 US. It's also a livelier engine at higher revs that will respond better to mods (ie SSI's). The downside is that it gets noticeably worse fuel economy and pollutes.
Back to the OP, a US 9.3:1 CR engine with a RoW CIS and distrubuter (or recurved stock dizzy) would make for a great engine, much like the 930/10 204 hp engine. However, to make it work, you have to modify the stock heads or use heads that already have the big ports.
Old 05-05-2013, 07:06 AM
carl74344's Avatar
so i guess the best thing to do is to make it all like new. keep my 1982 911sc the best by keeping it factory. make sure everything is set right. enjoy driving it. keep it clean, and have fun ....... thanks everyone.....carl
Old 05-05-2013, 05:57 PM
