Fahren mit dem Wind.
I just read with interest the thread on using RIT dye to recolor plastic parts. The velocity stacks on the early MFI's are plastic and mine are not all that pretty to lok at! So, I was wondering if anyone has tried the RIT technique on them or used some other technique to bring them back to life?
thanks, Michael
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net) Caregiver to: 1983 911 SC Cabriolet - Fahern mit dem Wind. (Moss Green Metallic over Champagne and Brown Leather) |
Michael, I found that mine responded to 0000 steel wool and plastic polish and the color came back just fine. The steel wool removed the crud, overspray etc. and the plastic polish (Mequires) took care of the rest.
I'd be curious if anyone else has tried other methods. BTW, while you have the stacks off, check the mating surface- you might find it's warped a bit. You can easily surface it using a large, flat piece of glass and some sandpaper.
Bruce Herrmann 97 C4S '04 330i '08 Cayenne S '07 4.8 X-5 |
where to find the gaskets?
I've looked at all the normal places and don't seem to be able to find the gaskets that go between the velocity stack and throttle bodies. Maybe I'm going blind? Anyone know where I can find these?
Michael
Friend of Warren
Uh, how about right here?Intake Suction Pipes to Throttle Valve Housing Gasket, 70-73 911 With Mechanical Injection, 6 Pack
C-110-191-01 $9.90 http://www.pelicanparts.com/catalog/shopcart/911E/por_911E_fuelij_main.htm
Kurt V No more Porsches, but a revolving number of motorcycles. |
but of course...
they are called "inlet suction pipe gaskets"! No wonder I didn't see them! Thanks!
Michael
I use some hylomar HPF gasket dressing in addition to the gaskets mentioned. It gives me a little more peace of mind and reduces the urge to tighten down the stacks (and warp them) to get rid of suspected intake leaks.
You would think it gets messy, but actually it's not that bad, and it comes right off with a paper towel next time you pull the stacks off. Hylomar is available at Pep Boys et al.
Jeff Keyzer 72 914 w/2056 built by Mark DeBernardi @ Original Customs Megasquirt with MSII upgrade |
