I would rather be driving
Been following this from the beginning. What a great build. Can't wait to see it finished.
Jamie
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I just skimmed this thread, awesome build Uwon. Good luck with your beautiful RST.-Matt
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels |
Uncertifiable!!!
[QUOTE=cxgh;8953974]I wonder if this case will lead to policy exclusions (if we hear you have ever been on a track then any claim will be void)?*********
See post 18. I would like to leave it at that. Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant Last edited by Bill Verburg; 01-12-2016 at 09:03 AM.. Reason: deleted spam from quote |
Uncertifiable!!!
Jamie and Matt, appreciate your comments. Thanks.
Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant Last edited by Uwon; 01-22-2016 at 07:43 PM.. |
Uncertifiable!!!
Finished the frunk electrical system, HVAC, etc. and installed hood.
. ![]() You may recall that this is a short hood chassis with a long hood that uses the short hood latch mechanism. ![]() Installed refinished gas tank and finished off the 16" spare tire in the same silver paint used on the rims. Had to do the leather strap thing . ![]() Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant Last edited by Uwon; 02-24-2016 at 06:42 PM.. Reason: Correction |
That looks real nice Johan!
Uncertifiable!!!
Thought it best to take some "selfies" of the front underside by placing the iPhone on the garage floor. This area will never be this clean again.
![]() ![]() ![]() ![]() ![]() Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
Uncertifiable!!!
A couple of setbacks over the last little while.
First, I missed that the master cylinder and booster from the donor crashed car was bent before installing it so when I tried to charge the brake system, I ended up with a booster canister full of brake fluid which overflowed into the frunk. Out came the water hose rather quickly. Fortunately the gas tank was not installed. You can read more about this misadventure elsewhere on this forum. Fortunately a fellow Ontario Pelican had a really good used booster which I married with a brand new, a.k.a. Expensive new 930 master cylinder. Note bent unit: ![]() Front of master-hollow piston end should be round: ![]() So while I was waiting for the new master cylinder to come from Germany, I finished off the fuel delivery system and charged it (pressurized it with the fuel pump without turning over the motor) with our Canadian 94 octane gas which promptly revealed a terminal fuel leak at the "T" junction of the t-fuel line which lies underneath the intake manifold. My choices were to dismantle the top end of the motor to remove and replace with a new Porschee issue, OR, bend and jank out the old one and replace it with a "soft"T-fuel line manufactured by fellow Pelican Len Cummings, all which does not require R&R of the whole intake system. Anxiously waiting for my package from Len! The culprit: ![]() On a more positive note, I tidied up the frunk. There is still some tape wrapping to be done of the wiring which I will undertake once the car is fully roadworthy. I really have little respect for my electrical abilities which makes searching for an electrical gremlin a dawnting task, especially for me. Leave it to me to add 7 additional fuses underneath the dash, 3 more on the main board, as well as a sh* t load of relays: ![]() Also installed all the parophenalia for the HID headlight system in a sub panel at the front: ![]() Finished off with some Rennline goodies: ![]() Frunk basically done. Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant Last edited by Uwon; 03-05-2016 at 08:51 AM.. |
Eng-o-neer
Zip ties in the unused fuse spots...I like that.
Can you tell me what those standard relays are mounted in? I always have trouble finding female relay connectors that take standard pins or don't already have too-small wiring attached. |
Banned
Looks awesome. I'm very interested in what all went into the new fuse and relays u added and what's all the relays?
Uncertifiable!!!
Hella relay base. http://www.hella.com/hella-us/assets/media/HINC_Electrics_Catalog.pdf Page 58, third one down. They interconnect. Got them locally from Carquest here in Canada. The female connectors with the little tabs that locks them into the base I got from Dell City in the U.S. Also got a reasonable crimping tool which is in valuable. Hope this helps. Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant Last edited by Uwon; 03-05-2016 at 03:28 AM.. Reason: Correction |
Uncertifiable!!!
Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant Last edited by Uwon; 03-04-2016 at 06:56 PM.. |
(man/dude)
Great work Johan. Looking forward to a ride in this thing someday
Uncertifiable!!!
Uncertifiable!!!
Motor Started
The new "soft" T-fuel line finally arrived from Len Cummings. Nice product, well made as one would expect from Len. It was easy to install-highly recommend this type of fuel line if you are not hung up on originality.
![]() Fuel pressure tested with no leaks. Made sure all the oil lines were still charged with oil before I turned the motor over with the coils and fuel pump on, and voila! motor fired up and first settled into a rolling idle. A bit of gas and warm up for 20 minutes.... ![]() No leaks-can't believe it..... until I carefully examined the bottom of the motor. Screw driver is pointing to the exact location of the leak between the stud and the bolt.. ![]() A closer look.... ![]() ![]() ![]() ![]() ![]() I have not yet re-torqued or restarted the motor. Thought that I would first seek some suggestions from the Pelican Brain Trust before going any further to solve this issue. So, if you have any suggestions, please bear in. I have cross posted into the Engine Building Forum so hopefully between the two I will get some ideas. Thanks in advance. Johan
(man/dude)
Congrats on the startup!
In the second pic of the leak (the one without the screwdriver) that's not a crack in the block, is it? (EDIT - NO IT ISN'T) Read the replies in the engine forum, good advice there. How long has the engine had oil in there? Perhaps the leak isnt really THAT bad, is it a single drop of oil over a period of months? Last edited by Jonny042; 03-18-2016 at 05:48 AM.. |
Uncertifiable!!!
Jonny,
Left over sealer and shadow is playing tricks. Here is a pic after initial cleanup. ![]() Johan
Counterclockwise?
Hi Johan!
We've talked about your car, but I didn't know this thread was here. I just read all 10 pages and it looks amazing! Hope to see you at Mosport this year. Rod
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Uncertifiable!!!
Hi Rod, Thanks for your kind comments. Yes, I'll be st Mosport in early May. I can also report that the oil leak has now been fixed thanks to the advise received in the 911 Engine Rebuilding forum particularly John Walker's Workshop. Got to love these forums! Car is now approaching completion and I hope that the weather warms up here in central Ontario soon to do a real road shakedown. More pics soon. Cheers, Johan
Counterclockwise?
Just to let you know what kind of stand up guy Johan is.
He still attends DE events (2 hours from his home) as an instructor even though he has not been able to drive his car during his rebuild.
