Need help Identifying Mahle aftermarket RSR looking piston on a 3.2?
Hello fellow pelicaners
Im looking to replace this piston but im not sure what it is? It looks like a 98mm 3.0 RSR Motorsport piston but my motor is a 3.2? from what I understand 3.0 and 3.2 piston aren’t interchangeable.
Did Mahle make a version of this piston for the 3.2’s. the new recently released (not MMortiz) Mahle P&C’s are different looking than mine which are probably an update.
Any mahle experts here to help decode these numbers?
Markings on the top:
Tiny “M” mark numbers are hard to see. I think they are 552 on top 0987 on the bottom of the M
Then 94,95 (mechanic measured pistons and its bigger from the bottom of the oil control ring chamfer all the way to skirt area. Is this normal?)
A big 0
Followed by 39/7
Markings on underside of the piston:
95P30 W2.
Anyone knows where I may be able to find these pistons?
Happy Fathers Day!
PF
Old 06-19-2016, 02:07 AM
The pin size is the difference from 3.0 to 3.2.
3.0 pin is 22mm, the 3.2 is 23mm
Bruce
Old 06-19-2016, 03:30 AM
Yes that's why 3.0 aren't interchangeable with 3.2
Old 06-19-2016, 09:07 AM
mod...please remove this thread?
ive moved this over to "engine rebuild"
thank you pf
Old 06-21-2016, 03:10 AM
