LinkBack | Thread Tools | Rate Thread |
Need help Identifying Mahle aftermarket RSR looking piston on a 3.2?
Hello fellow pelicaners
Im looking to replace this piston but im not sure what it is? It looks like a 98mm 3.0 RSR Motorsport piston but my motor is a 3.2? from what I understand 3.0 and 3.2 piston aren’t interchangeable. Did Mahle make a version of this piston for the 3.2’s. the new recently released (not MMortiz) Mahle P&C’s are different looking than mine which are probably an update. Any mahle experts here to help decode these numbers? Markings on the top: Tiny “M” mark numbers are hard to see. I think they are 552 on top 0987 on the bottom of the M Then 94,95 (mechanic measured pistons and its bigger from the bottom of the oil control ring chamfer all the way to skirt area. Is this normal?) A big 0 Followed by 39/7 Markings on underside of the piston: 95P30 W2. Anyone knows where I may be able to find these pistons? Happy Fathers Day! PF ![]() ![]() ![]()
The pin size is the difference from 3.0 to 3.2.
3.0 pin is 22mm, the 3.2 is 23mm Bruce |
Yes that's why 3.0 aren't interchangeable with 3.2
mod...please remove this thread?
ive moved this over to "engine rebuild" thank you pf |
