randy (guest)
Guest
Posts: n/a
following your insturctions for engine removal for my 1980 sc, got everything done but two parts 1. the large arm on clutch will not come off, it seems the whole shaft wants to pull out bottom of trany, any help? 2. i'm not removing trany so does reverse light conection have to come apart, this wire is a real pain to get to, any help?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Engine Removal - 911 (1965-89) - 930 Turbo (1975-89)
Old 05-09-2013, 01:24 PM
Nick at Pelican Parts's Avatar
Not sure I follow what you are describing when referring to the clutch arm. Any chance you can share a photo?
You have to disconnect the reverse light switch when removing the engine and transmission together.
- Nick
tonypai's Avatar
The clutch arm I think you're referring to is held in place by a snap ring. Remove that and the whole piece drops straight down.
2001 Suburban - Tow Vehicle
2000 Miata - Race Car
1996 993 Carrera - Daily Driver
1981 911 SC RoW - Wannabe Race Car
Old 05-09-2013, 02:17 PM
Senior Advisor
James Brown's Avatar
removing the clutch cable and the 2 springs is all you need, the arm just moves off the throw out bearing as the engine separates from the transmission.
08 Cayenne Turbo
Old 05-09-2013, 02:36 PM
fred cook's Avatar
Clutch arm......
The first time I pulled the engine/tranny out of my SC, both of the clutch arms were seized on the shaft. I wound up using a modified hub puller to get them off. While they were off, I cleaned up the shaft and made sure it was lubed when I put it all back together. I just pulled the engine/tranny out again last week and had no problems getting them off. Good luck!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 05-09-2013, 03:46 PM
schumicat's Avatar
the reverse light switch does not have to come off if you are dropping the whole drivetrain.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 05-09-2013, 06:07 PM
pete3799's Avatar
Check the large clutch release lever....some years used a roll pin to hold it on.
Pete
79 911SC RoW
Old 05-09-2013, 06:19 PM
