Part number needed please!
I am working on a total re-seal of the oil leaks on my 85 Carrera. I have a different thread about that.
One of the many (endless) "while I am in there" projects is the intake. Since the intake is off now is the time! I want to replace all the rubber bits that cause vacuum leaks.
This rubber "Y" is what I need. This one is likely the one that the car came with. 146,000 miles and 28 years ago.
It connects the pressure regulator via a little hard plastic hose to a rubber elbow on each bank. The Pelican catalog has this part superseded with part number 928-573-727-02 but that is a hard plastic part.
Any ideas on where to get the correct part? What part number do I need?
Old 05-10-2013, 12:53 PM
rsscotty's Avatar
This is the part for a 993 intake system that uses the same size as your vacuum lines.
928 573 727 05
Old 05-10-2013, 01:46 PM
928 573 727 05
OK, thanks. I wish the catalog had a photo or a description of that part number.
Old 05-10-2013, 02:02 PM
rsscotty's Avatar
Vacuum tee
Part number superceded to 05
Old 05-10-2013, 03:17 PM
I ordered the 05 part number. It has to come from Germany. Ah well it is just time and money. Thanks for your input. I appreciate it.
Old 05-10-2013, 06:34 PM
