nicfranc's Avatar
297K miles on original unopened engine ???
I recently purchased a 1980 911sc from a friend who was the original owner.
The engine has never been opened and has not had any major work done to it.
It never has had a broken head stud nor does it have a Pop-Off valve.
It has the original chain tensioners as opposed to the pressure fed tensioners.
So my question to you is:
is this car and its engine just an anomaly ?
The car has had regular maintenance for 33 years and has managed to survive without a pop-off valve or pressure fed chain tensioners so why would I add them now ?
Why not just rebuild or replace the existing tensioners and add collar clamps as protection against catastrophic failure ?
I have replaced the CAT with an M&K Pre Muffler and replaced the stock muffler with an M&K single in single out Sport muffler.
The car had the O2 sensor disconnected years ago.
The car starts right up and runs great. It does not burn oil.
I have tuned it up and plan on checking the existing chain tensioners and ramps in the upcoming weeks.
Note:
Carerra pressure fed chain tensioners are $1,214.
Would the Pop off valve introduce possible vacuum leaks as Peter Zimmermman has mentioned in his book.
Your thoughts ?
1980 911sc Petrol Blue Metallic Targa, 300,000 + miles
M&K Pre Muffler + M&K 1 in & 1 out Sport Muffler
Previously owned and rebuilt:
60's VW Bugs, Buses & Ghias
Old 05-10-2013, 08:22 PM
1983 911SC Chiffon Weiss
mlfox's Avatar
If it ain't broke, don't fix it.
Old 05-10-2013, 08:24 PM
..I wouldn't mess with it, other than the tensioners (do check those)...Seriously, leave it be as there is mojo working inside that case and doing anything drastic might release those spirits...and it may unravel.
Post some pics.
Old 05-10-2013, 09:11 PM
porschetub's Avatar
Post some pics.
Bruce Anderson (RIP legend) talked in Excellance about valve guides failing,or head studs pulling,remember he said they don't all do it and he had seen those motors with HUGE mileage ,so cool this is one,put chain savers on the tentioners and drive it and enjoy,don't touch it.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 05-10-2013, 11:21 PM
lateapex911's Avatar
Yea, Bruce loved the SCs. They can really run for miles and likes. (Nice change from the 76s etc.)
Put the tensioners on it, and get some compression numbers as a benchmark.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 05-10-2013, 11:31 PM
Speed Dog's Chauffeur
Dodge Man's Avatar
da' valves
I have a friend that rode his super cherry 78 SC until it dropped a valve after he spent $3000 removing door dings and getting 8" rims for the rear. The high mileage is cool but valve train components are where the real wear happens. You have a clean numbers car so make sure that you do not ruin the case. It is a defensive strategy but at 297K is it worth a risk? M2CW Research a good shop to do the top end and freshen up the trans (syncros, etc...) if you plan to keep the car long term. Nice buy.
Old 05-11-2013, 01:19 AM
AutoBahned
RWebb's Avatar
it IS an anomaly in the sense that not many go that far without being crashed, hot-rodded or just sitting in a garage all the time w/o getting that many miles
I've heard of a few with 400k on them, so it is not a high mark
Old 05-11-2013, 12:36 PM
nicfranc's Avatar
400k !
400K ! I would sign up for that right now.
I also read that someone had a car with 475 K on the original engine.
I will plan on a total rebuild in the future but in the meantime it runs great
and I love driving it.
Old 05-11-2013, 01:23 PM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
The highest mileage car I have seen on Pelican was a 964 with 521k. The engine had been rebuilt at least twice, with many aux. components replaced 3 or 4 times, and given a 10k repaint. It was in the classifieds either last year, or the year before. Just thought I'd share.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 05-11-2013, 02:26 PM
912 Geek
Not an anomaly: A friend from the Pacific Northwest put well over 300,000 miles on his SC (bought new) without engine work, and that was at least 20 years ago, so it would have more on it today.
Frank ('65 912, 180,000 mi; '95 MB E320, 197,000 mi)
Old 05-11-2013, 02:33 PM
I have 350k on my unopened 3.2 engine - only 'wear' I know of is the timing chains are stretching and this is letting the tensioner idler pulleys move closer to the engine case. I'm going to try cutting off the chains and spinning in new ones this summer.
Chuck.H
'89 TurboLookTarga, 352k miles
Old 05-13-2013, 05:45 AM
