Several questions ...
1. Does anyone know where I can find the plastic housing for the headlight bulb (H5) in pictures below? It's not on the dialgram on this site, nor at the dealership.
2. What is a good substitute for the insulation padding found under the seats (see pic below)? I had to throw out alot of mine because it was waterlogged.
3. Can anyone recommend a good adhesive for gluing the padding to the metal below? And (if different) a good adhesive for gluing the carpet to the cardboard insulation material below?
Thanks in advance!
Old 05-14-2013, 08:32 AM
DrkJstc's Avatar
Send a message via AIM to DrkJstc
I may have the plastic housing, you can have it for the cost of shipping. Let me check the garage, PM if interested.
Old 05-14-2013, 01:25 PM
Less brakes, more gas!
euro911sc's Avatar
1) no idear. come with a new lens perhaps?
2) I believe they sell that stuff. You are talking about the padding that is found under the carpet correct? If so it should be easy enough to find:
Carpet Padding - JCWhitney
Google turned up several other places as well.
3) 3M Super 77 or a variant there of. Can be found at your local auto store in a spray can. Follow the directions on the can and be happy.
Good luck!
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 05-14-2013, 01:36 PM
nineball's Avatar
Good luck!
i would suggest the 3m foamfast 74 over the super 77. it's what i used when i installed my new interior and i could not be happier. the nozzle has 3 settings built in for varying spray widths. you won't be able to find it locally but it is all over the net.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 05-14-2013, 03:21 PM
Rescuer of old cars
Arne2's Avatar
Last time I glued foam (prior to the P-car) I used 3M Hi-Tack 76. I like it better than Super 77 for foam. The 74 sounds like the best option, though.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 05-14-2013, 04:50 PM
winter
Winter's Avatar
Nineball did an amazing job on his interior and his thread on the process taught me a lot (I'm on my phone or I'd link it here, but do a search). I'd defer to his advice, but that's just me.
Old 05-14-2013, 07:08 PM
