Jbizzle78's Avatar
Can You Turn 996 Rotors?
Can you turn 996 cross drilled rotors?
1971 911 T
1994 911 C4 Widebody - Daily Driver
2006 BMW E90 Sedan
Old 05-14-2013, 02:44 PM
Rescuer of old cars
Arne2's Avatar
It's my understanding that no cross-drilled rotors can be turned. The machine tip would catch on every hole.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 05-14-2013, 03:51 PM
millarg's Avatar
Sorry to hi-jack, but never considered this, I have a 78 SC, with standard rotors, can these be rotated? And what is the benefit?
Glen 78SC(D) EFI Targa
Old 05-14-2013, 04:43 PM
wwest's Avatar
Yes, they can be turned, but labor rates are such that it is often less expensive to just buy new.
Old 05-14-2013, 04:56 PM
This isn't true - I've turned my 930 type rotors several times, the bit is held so firm by the lathe it passes right over the holes. Remember, it's not being 'pressed' into the rotor, just held in place. But I agree, they have become so cheap I now just buy new ones.
HTH,
Chuck.H
'89 TurboLookTarga, 352k miles
Old 05-14-2013, 05:03 PM
I bought new rotors when I fitted 996 brakes - set of 4 Balo rotors was $300 drop-shipped. They came in Sachs waxed paper.
For that money, it's hardly worth messing about. '78-79 930 floating front rotors at $350 a pop? Yeh, I would think it would be worth turning those down...
'77 S with '78 930 power and a few other things.
Old 05-14-2013, 05:20 PM
Chain fence eating turbo
They are not "turnable" rotors but you can turn them. BTDT.
Catch my drift?
P.S. - they are very hard on cutters.
Old 05-14-2013, 07:49 PM
Best to check this on some 996 forum...
Old 05-14-2013, 08:59 PM
Northern Motorhead
wildcat077's Avatar
I just replaced my 996TT rotors which had multiple cracks spreading from the holes with Sebro slotted units ... i highly doubt turning a 996 rotor would be a wise decision seeming as you are removing even more heat absorbing material !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 05-15-2013, 07:16 AM
I checked a while ago as my 930 rotors started to give me a little lip. The correct procedure is apparently to have them ground, specifically Blanchard grinding, according to the factory.
Having said that, I have never found anyone who offers Blanchard grinding as a service, and any request of a machine shop that I have made resulted primarily in blank looks and strange comments.
D.
Old 05-15-2013, 11:09 AM
Banned
With rotors that have holes, I wouldn't turn them. I'd just buy new.
Old 05-15-2013, 11:19 AM
