OCPO
Front A/C Blower motor gasket part number?
Anyone know if this foam gasket is available from our host?
2018 X5 86 911 Targa 3.2 80 Mercedes 450SL 2006 530xi BillyBoat/H&R's....gone |
If the host does not show it (its not in PET),
then any closed-cell foam, such as a rubber, Neoprene, EPDM, or a simple Buna, will work for the task. A soft low durometer, say 5-9 psi, 1/4" thick, 1/2-3/4" width will conform for ya. You can try on-line at McMasterCarr, or brick and motar Big Boxes like Home Deposit or Lowes: Frost King brand products (black, rubber, closed cell). Anything that will allow you to remove the blower assembly should you have to; no adhesives, epoxies, glues.. etc. The corners of the plastic rectangular base on the blower assembly break often, just use a large OD stainless washer under the original screw to hold them down. |
