| wwest |
06-14-2013 08:51 PM |
Originally Posted by big911fan
(Post 7499236)
OK. It's time for me to get off the fence and offer my opinion too.
I doubt very much it has anything to do with over-pressurization.
Why? Because my system continues to lose pressure over the winter. I don't drive my car in the winter so the A/C is never turned on.
Duplicate of my experience, car got parked late fall, not driven again until spring. But how soon do you notice an A/C short-fall? For me it was only as the days, drives, got warmer and warmer. The A/C would seem to be more than adequate early on, but once real HEAT arrived, August say, it clearly was not operating as it did last August.
How can over-pressurization be a factor in refrigerant loss then?
yes, a bit of a puzzle, for me also. But what is a reasonable, logical, alternative explanation for the FACT that this leakage does not occur in the millions of vehicles using this same hose. Kuehl spouts, as a rebuttal, that we are the only ones wih 9 feet of hose. Even were that true (it isn't) wouldn't there be SOME indication that other cars are exhibiting this failure. After all, don't those "other" cars out number "us" by at least a million to one?
Where IS the BEEF..?
It can be hoses though.
Is there a flaw in my logic?
No, but logic, given the overall information available, does not explain the disparity between our cars and those of others of this same era regarding the loss of refrigerant.
A bit of poorly supported speculation. Meager evidence might indicate that the loss of refrigerant occurs more rapidly as one moves south. I keep seeing twice yearly in TX, whereas around here every 2 years seems to be more common. Hotter climates, higher pressures, more A/C use.
It does seem hard to imagine that fully equalized refrigerant during the summer might be, what, 75 PSI "tops", maybe 35 PSI otherwise would leak. Neither of those numbers inspire me to the belief that leakage occurs during non-use.
So pressure seems to me to be the tie-breaker.
