Need new eyeglasses? 2 PRIMARY naysayers... |
Still waiting on the video...
Not a naysayer at all. Just want proof one way or the other. What I have works just fine. I just merely disagree with your NUMEROUS comments that what I have is just snake oil. When in fact it does work. If yours works better, then all I ask for is video proof since you dont have 100's of people who will verify it like Kuehl and Zims and Rennaire does.. seems reasonable to me. Quote:
800psi high-side pressures. 78 degrees is "the standard" for comfort. Cavitation of ANY kind in a gas. Decklid fans offer no restriction for engine cooling air. High pressure causing leaks at fittings. There is zero evidence/support for ANY of these assertions. Personal preference or opinion does NOT count as evidence or support. With all the false and misleading stuff that wwest types, how could ANYONE take anything he says at face value? |
Guess I am a Naysayer as well then. I agree with you. LOL
After a car is driven and you turn off the engine, does the high side rise? If the high side did rise does it rise above normal operating pressures? If you decide to run fans or anything off a trinary switch be sure you know how many amps the feed line can carry. ;) |
You're the TWO..!
The video please... LOL
They will leak & I can prove it. Why would anyone believe the stinking EPA ????
I wish my legacy hose didn't leak...:(
Lol
Ready for NAYSAYING......GO!
http://forums.pelicanparts.com/porsche-911-technical-forum/755872-pertronix-coil.html#post7498163 |
Shoot the damn video WWEST.
Question for Kuehl... It appears (numerous posts) that evaporator freeze-up is a fairly common occurance, inclusive of a few occurances (high mountain passes) of my own. Then why does, apparently, the compressor not be damaged via slugging? In my own case there seemed to be no detectable system airflow, indicating that the evaporator was now simply a block of ICE. Since that ice becomes a PERFECT insulator why would liquid refrigerant now not flow directly to the compressor inlet? How quickly does/will serious damage to the compressor result? |
| All times are GMT -8. The time now is 12:14 AM. |
